turning a 4 door into a 2 door. #1250146
06/12/12 11:31 PM
06/12/12 11:31 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
my uncle wants to take a clean 65 plymouth belvedere 4 door and turn it into a 2 door post with a doner car to run in nostalgia super stock we have heard it can be done fairly easily. What I was needing was an article on how to do this or some good step by step pictures if any of you have done this before.
Thanks guys!
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250147
06/13/12 12:11 AM
06/13/12 12:11 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
I have seen pictures of it being done. Do not remember where now. On Bigblock Dart there was a guy who did that with a Dart. If I remember the article on the B body the spots to mount the post to make it a 2 door car were on the structure of the 4 door car.
Still Broke
Re: turning a 4 door into a 2 door. [Re: Chucklehead] #1250148
06/13/12 12:17 AM
06/13/12 12:17 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The doors are kinda hard to come by, plus the brain damage. Just buy the post car and be done with it.
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250149
06/13/12 12:25 AM
06/13/12 12:25 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I've never done it, but here's a set of photos showing it done. http://s20.photobucket.com/albums/b248/lil273/
Another page with info http://www.forbbodiesonly.com/moparforum/showthread.php?t=26525
Everybody makes fun of a hillbilly until they need something fixed
Re: turning a 4 door into a 2 door. [Re: B_Body_Bob] #1250150
06/13/12 02:19 AM
06/13/12 02:19 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thaank you very much that was exactly what I was looking for! I like the way the forbbodies only one used the skin off the old door for the patch piece! Thanks again
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250151
06/13/12 02:34 AM
06/13/12 02:34 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
This was a 4 door in its previous life
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250152
06/13/12 05:20 AM
06/13/12 05:20 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Yes, that's relatively easy, just keep in mind that the profile of the b-post in a 2 door is different than in a 4 door, so you still can't do it using 2 D doors and just moving the 4 D post rearwards and covering the hole with the partial skin of the 4D. The B-post needs modifications to make it work. Same is true with A-bodies, and on top of that the B-post of the 4 d is way thicker, so that the 2 D sedan rear side glasses won't fit.
Here is some pics of a bit more radical conversion http://www.moparmaniacs.net/belveframe.html
And here is a pic of a converted A-body with the thick B-post: http://kuvia.1g.fi/kuvat/Tapahtumat+2011/FHRA/SonaxSpringNats2011/Camera2/MOP_7902.jpg
Plynouth VIP '67 TT IC EFI
Re: turning a 4 door into a 2 door. [Re: jyrki] #1250153
06/13/12 09:04 AM
06/13/12 09:04 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
A few years ago I saw an article on a dark blue 62 Belv/Fury that had been converted, you might be able to find that article somehow.
It was on the cover, on a low-angle shot that let you see the turned-inside whitewalls (why didn't they photoshop that?).
Re: turning a 4 door into a 2 door. [Re: Fury Fan] #1250154
06/13/12 09:10 AM
06/13/12 09:10 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Re: turning a 4 door into a 2 door. [Re: B_Body_Bob] #1250155
06/13/12 09:25 AM
06/13/12 09:25 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Somebody needs to change youre title from 'master of nothing' to 'lickety-split netsearcher'.
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250156
06/13/12 10:16 AM
06/13/12 10:16 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
...we have heard it can be done fairly easily.
Re: turning a 4 door into a 2 door. [Re: Commando1] #1250157
06/13/12 10:52 AM
06/13/12 10:52 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Just like a 5.7 swap.
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250158
06/13/12 12:36 PM
06/13/12 12:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm sure it can be done, but not easily.
A different question: what do you say when the tech guy says "it's not legal"?
How do you prove it's an exact match for a 2-door, with no weight distribution, engine location, axle position etc. changes?
Boffin Emeritus
Re: turning a 4 door into a 2 door. [Re: Jonnyj00] #1250159
06/13/12 12:56 PM
06/13/12 12:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think he'd be better off and he'd save some money by just selling the 4 door and buying a 2 door. That or just race the 4 door in NSS.
Coming soon!!!!
Re: turning a 4 door into a 2 door. [Re: Mr.Yuck] #1250160
06/13/12 01:21 PM
06/13/12 01:21 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
A 4 door and post car use the same chassis/roof. When the car is built as a post an interior 'plug' is used where the back window is. To do the job correctly, a post car donor needs to be used for the plug/jamb, post/glass and doors.
It doesn't make sense to me to do all that work since a donor post car needs to be located anyway.
Then there's the issue of getting someone to sell you a car knowing you're going to cut up a post car to build a post car...
Re: turning a 4 door into a 2 door. [Re: 64Post] #1250161
06/16/12 12:59 AM
06/16/12 12:59 AM
Washington State, USA
W
Winchester 73 Offline
W
unless you were creatin a car that dident exist like a two door c body wagon someone with photoshop skills do me a two door 72 town and country wagon pleeeeeeeese
