HEMI Pulleys - Bouchillon Performance #1249469
06/11/12 10:26 PM
06/11/12 10:26 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I picked up these Hemi Pulleys last week made by Bouchillon Performance. The crank pulley is a double groove for Power Steering. Does the water pump and crank pulley look correct? Something is not right here.
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249470
06/12/12 12:55 AM
06/12/12 12:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What year did you buy them for ? The water pump pulley is not the 69-71 repop.
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249471
06/12/12 03:24 AM
06/12/12 03:24 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Look like the OEM pulley's on my 440. PS is a little larger. WP and crank line up?
Re: HEMI Pulleys - Bouchillon Performance [Re: 70Duster440] #1249472
06/12/12 11:01 AM
06/12/12 11:01 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I like the larger top pulley for belt gripping. I don't see a problem with the pulleys as you have good belt alignment.
MLR426
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249473
06/12/12 12:17 PM
06/12/12 12:17 PM
AndyF Online content
AndyF  Online Content
If it is for a street car you might want a smaller pulley on the water pump.
Re: HEMI Pulleys - Bouchillon Performance [Re: AndyF] #1249474
06/12/12 12:24 PM
06/12/12 12:24 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
It is for a street car. I just have never seen the crank and water pump pulley that close to each other. They do line up.
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249475
06/12/12 12:53 PM
06/12/12 12:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'll give you a heads up now.
Media blast the paint off they use. then scuff the belt grove with something like 80 grit , then repaint.
I had a lot of belt squeels till I did just that
Re: HEMI Pulleys - Bouchillon Performance [Re: gtx6970] #1249476
06/12/12 09:01 PM
06/12/12 09:01 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Use the large pulley it gives better grip for the belt and during high RPM rev's you will need it.
Use a high volume water pump, it's pretty much a must use part.
MLR426
Re: HEMI Pulleys - Bouchillon Performance [Re: MLR426] #1249477
06/12/12 09:40 PM
06/12/12 09:40 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
So it sounds like this pulley set up is normal. I just have never seen the crank pulley and the water pump pulley that close to each other.
Re: HEMI Pulleys - Bouchillon Performance [Re: gtx6970] #1249478
06/12/12 10:28 PM
06/12/12 10:28 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I had a lot of belt squeels till I did just that [/quote
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249479
06/13/12 12:44 AM
06/13/12 12:44 AM
I don't think that is a normal combination of pulleys, but that doesn't mean that it won't work. You'll just have to try it and see. For a street engine you would probably want a smaller water pump pulley in order to move more water. The combination you have on there right now looks more like a circle track setup that slows the water pump down for higher engine speeds.
Re: HEMI Pulleys - Bouchillon Performance [Re: faud88] #1249480
06/13/12 01:09 AM
06/13/12 01:09 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I really don't think you have anything to be worried about. These are OEM pulleys on my 440. Yeah, they're close together. Been running them for years - no issues. I had them powder coated before actually putting them into service. No slippage, no squeals. In fact, the powder coat has not worn out of the grooves. I can tell you that if your PS belt flaps at all it may contact the WP pulley and mar the finish.
Re: HEMI Pulleys - Bouchillon Performance [Re: AndyF] #1249481
06/13/12 01:38 AM
06/13/12 01:38 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I wouldn't worry about it. Ask the folks at BPE about them.They sold them to you. Those guys & gals are very knowledgable about thier parts & will explain any worries that you have.
Cars with low gears on the street would probably benefit from those pulleys especially being that the coolant will slow down enough to absorb heat instead of flying by at a higher rpm
That's why the circle track boys run a setup like that
Re: HEMI Pulleys - Bouchillon Performance [Re: BulletBob] #1249482
06/13/12 02:55 AM
06/13/12 02:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Call and talk to JR, he knows his mopar pulleys.
And I have bought 2 sets from them and they fit perfect and don't squeal.
I drove one of them yesterday at 120 miles per hour for miles in NV. In other words I drive em, I know.
If they squeal then you have the wrong combo of pulleys imo.
Re: HEMI Pulleys - Bouchillon Performance [Re: Challenger 1] #1249483
06/13/12 09:41 PM
06/13/12 09:41 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I glass bead the grooves, In the past my experience with powdercoated pulleys has had some squealing here & there,not every set but I strip the groove on them anyway
Re: HEMI Pulleys - Bouchillon Performance [Re: Challenger 1] #1249484
06/14/12 12:44 PM
06/14/12 12:44 PM
None
71rm23 Offline
71rm23  Offline
None
THATS what I'm talkin about Gary!
