Any tips to installing a tranny side cover on the car? #1249444
06/11/12 09:36 PM
06/11/12 09:36 PM
Connecticut
JFAbody Offline OP
JFAbody  Offline OP
Connecticut
I have a 72 Duster with an 833, I pulled the cover to...(don't ask why) but I can't get the thing back on, any tricks or should I just pull the whole thing down?
72 Duster 340 4 Speed
Re: Any tips to installing a tranny side cover on the car? [Re: JFAbody] #1249445
06/12/12 12:06 AM
06/12/12 12:06 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If you put the 3-4 shift fork on the cover and get it started you can use a screwdriver (or whatever tool you choose) to raise the 1-2 shift fork into place and then push the cover all the way on. Once you get the 3-4 shift fork in it helps to put a few bolts in to hold the cover.
Patience...
Re: Any tips to installing a tranny side cover on the car? [Re: Jeremiah] #1249446
06/12/12 12:57 AM
06/12/12 12:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Patience...
What he said , I've had to do it twice after breaking the 1-2 fork in 2 different cars .
Re: Any tips to installing a tranny side cover on the car? [Re: JohnRR] #1249447
06/12/12 01:08 AM
06/12/12 01:08 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
As John indicated if you have it apart now would be a good time to install steel shift forks. If you plan on shifting the trans hard with the bronze shift forks you will be driving home in (my guess is) third gear.
Let me guess...you put the shift levers/tabs on the trans upside down and it wouldn't shift so you took it apart?
