They Certainly Don't Give The Win Lights Away.....Geesh
#1248979
06/11/12 09:24 AM
06/11/12 09:24 AM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Dunn Tire Park Mopar Day...
Well, we got the valvetrain sorted out, the brakes sorted out, the 2-step wiring sorted out, trans brake sorted out, the four link sorted out, get to first round, cut a .527 light off the 2-step with the trans brake to the other guys .503....Aaargh! And I am a first round LOOSER!
Still had a blast
Re: They Certainly Don't Give The Win Lights Away.....Geesh
[Re: Dragula]
#1248980
06/11/12 09:32 AM
06/11/12 09:32 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Welcome to delay box racing. Typically if you aren't 00 on the tree you aren't going to win many races.
[Re: Dragula]
#1248981
06/11/12 09:46 AM
06/11/12 09:46 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
What happened to Run with What you Brung Heads Up racing????? Pedal to the metal from start to finish. Put up or shut up. Now it's who has the most trickery installed and who has the better psychological strategy... Just put a trained chimpanzee in the seat and let the 'puters do all the work. All you guys under 40 can flame a way now.
[Re: tboomer]
#1248984
06/11/12 10:01 AM
06/11/12 10:01 AM
Guitar Jones
When I race in a no box class I use the two step starting line rpm to fine tune my reaction time along with an adjustable button. My first hit with it at the finals last year was .000, but it all went down hill after that.
[Re: Guitar Jones]
#1248985
06/11/12 10:32 AM
06/11/12 10:32 AM
Posts: 3,448 Dandridge TN
Dabee
Dandridge TN
Okay I guess I’m going to stir the pot here a little. If you are foot brake racing use the foot brake period! Trans brakes and two steps don’ belong there!
If you want to control the launch rpm look at your tack when you bring the rpm up. Some tacks even have a feature that will flash the shift light to assist with launch rpm.
[Re: Dabee]
#1248986
06/11/12 10:46 AM
06/11/12 10:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Up here in this division the trans brake is allowed so why not use it... I do... that way if I want I can enter box and no box by just putting the box in which takes just a few seconds(but I learned that its hard to go from top light to bottom light round after round)
[Re: Dabee]
#1248987
06/11/12 10:48 AM
06/11/12 10:48 AM
Guitar Jones
Pro ET here allows a two step and a trans brake. They also allow automated shifters. But no delay box or throttle stops. Thus the "No Box" or "No Electronics" class not pure foot brake, that's different. But I will also race pure footbrake using the tach as you described to launch. No pot stirring necessary.
[Re: MR_P_BODY]
#1248988
06/11/12 10:50 AM
06/11/12 10:50 AM
Guitar Jones
Hey Mike, I overcame that problem by leaving off the bottom bulb in any class. I know I probably give up something there but I'm used to doing it that way.
[Re: Guitar Jones]
#1248989
06/11/12 10:55 AM
06/11/12 10:55 AM
Dragula
I normally run the car as a foot brake only...
What I have learned though, its 512 cubes, and any difference in launch rpm, changes the reaction time. I would still want to run the 2-step with a foot brake to make sure I get the right launch rpm because it makes too big of a RT differnce and it has lost me a race or two.
So, the way I look at it, if its allowed, I will run it. The button I have is adjustable, but I have not tinkered with it yet. I cut a .512 in time trialas so i figured I was close enough...
[Re: Dragula]
#1248990
06/11/12 08:33 PM
06/11/12 08:33 PM
Posts: 20,190 Park Forest, IL
slantzilla
Park Forest, IL
Watch time runs on any Sunday at RT 66 and you will see .00X lights pop up like candy in SPORTSMAN. No 2 steps or brakes allowed, true footbrake only. I can usually go .01X in my pickup in time runs. Can't seem to do it in the first round though. I've got a buddy who has been racing the same 5.0 Mustang for almost 20 years. If he goes .020 he is dead late.
[Re: slantzilla]
#1248991
06/11/12 10:59 PM
06/11/12 10:59 PM
Dragula
As I said, I have 7 total passes on it this way, and I am already in the .535 or better range consistently...
Off the foot brake alone, we kept finding things in the front end that would change the RT, and since we have yet to have it super consistent off the foot brake week to week, we will go the route of least resistance.
The drum brakes would have to go, and I think we would need heim jointed a-arms. There is too much slop in the ancient originals.
