need pictures 1970 b-body 4 speed clutch adjustments #124869
09/23/08 12:07 AM
09/23/08 12:07 AM
Ontario, Canada
B5Superbird Offline OP
Ontario, Canada
I'm looking for pics of the correct assembly for the clutch adjustments on a 1970 Road Runner.. The way the adjuster nuts, washers and spring goes
thanks
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: B5Superbird] #124870
09/23/08 11:55 PM
09/23/08 11:55 PM
Ontario, Canada
Ontario, Canada
bump
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: B5Superbird] #124871
09/24/08 02:40 PM
09/24/08 02:40 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Another key point is to make sure you have the rite Z-bar.. The adjusting rod from the fork to the Z-bar should be parallel to the bellhousing..
This assures less slop in the linkage.
We have seen certain installs where the adjusting rod is angled going to the fork/bell housing. The differences are due to the mounting position of tab(on the Z-bar)that the adjusting rod goes into. As there are a couple of different Z-bars of the same length but have different position for the mentioned tab.
Just my ..
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: Sinitro] #124872
09/24/08 09:51 PM
09/24/08 09:51 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I hope this helps.
From the 70 Plymouth Service Manual.
Click on attachment for larger picture.
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: Snoopy] #124873
09/24/08 10:33 PM
09/24/08 10:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: gtx6970] #124874
09/24/08 10:33 PM
09/24/08 10:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: gtx6970] #124875
09/25/08 12:17 AM
09/25/08 12:17 AM
Snoopy Offline
Snoopy  Offline
Bill,
Anyone reproducing these?
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: gtx6970] #124876
09/25/08 02:55 AM
09/25/08 02:55 AM
Snoopy Offline
Snoopy  Offline
It looks like B/E&A has them.
I wonder if it has the keyed hole and the flat sided rod like the originals?
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: Snoopy] #124877
09/25/08 06:54 AM
09/25/08 06:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bill,
Snoop
Isn't that a truck application piece ?
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: Snoopy] #124878
09/25/08 06:58 AM
09/25/08 06:58 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Bill,
Just use a Chevy rocker arm ball pivot. I have been doing it for years with no issue. It's not keyed, but never had any problem. Just use a little EP High pressure grease.
Works great. Better than that crummy plastic washer insert, which always breaks.
MB
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: HPMike] #124879
09/25/08 10:26 AM
09/25/08 10:26 AM
Ontario, Canada
Ontario, Canada
Thanks that's exactly what i needed.. I wasn't quite sure which way the lock nut was supposed to go..
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: gtx6970] #124880
09/25/08 11:41 AM
09/25/08 11:41 AM
Snoopy Offline
Snoopy  Offline
Snoop
It may have been a truck part originally, but it is listed in the 70-71 Passenger Car Parts Catalog as a 71 B & E-Body part. It looks like it replaced the washer and rubber piece in 71. The 72 - 74 parts books list it for A, B & E-Bodies.
P/N 2401740 - Release fork adjusting swivel.
Here is a comparison picture of the Chevy rocker arm ball pivot and the Chrysler swivel,
Re: need pictures 1970 b-body 4 speed clutch adjustments [Re: Snoopy] #124881
09/25/08 11:55 AM
09/25/08 11:55 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
This car is using the Chevy rocker pivot on the fork. Two plus years of 11 second passes behind a 600+ HP motor and zero issues. I suppose it would last 100 years behind the average trailer queen.
