need a coil recomendation #1247586
06/09/12 12:49 AM
06/09/12 12:49 AM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
I have a 440 six pack with the mp electronic ignition conversion on it now with stock coil. Will be adding a msd 6a in the near future what coil should i run with it. There is so many out there, which ones have you guys had good luck with? Thanks in advance ozz
Re: need a coil recomendation [Re: ozz383] #1247587
06/09/12 01:20 AM
06/09/12 01:20 AM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
Mallory promaster and accel coils are supposed to be the best with the mopar boxes and new rev-n-ator. Msd blaster coils work the best with a msd ignition.
Re: need a coil recomendation [Re: ozz383] #1247588
06/09/12 07:46 AM
06/09/12 07:46 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
with sticking to matched components. go with the blaster, i would recommend getting this one - http://www.msdignition.com/Products/Coils/Race/8222_-_High_Vibration_Blaster_Coil.aspx - which i will be moving over to. they also fit nicely in the 6-pac coil mount bracket . once you switch your ECU over to MSD you can also safely toss your ballast resistor.
Re: need a coil recomendation [Re: mikemee1331] #1247589
06/09/12 12:41 PM
06/09/12 12:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree MSD.Mine with 6AL is 12 years old and no problems ever.My kid just did have to replace his Blaster with the 6 Digital.It was at least 15 years old and had tons of miles as does mine.Rocky
Chrysler Firepower
Re: need a coil recomendation [Re: ozz383] #1247590
06/09/12 01:02 PM
06/09/12 01:02 PM
Kirkland, Washington
Pacnorthcuda Offline
If you want a can coil (for cosmetic reasons) then a Blaster high vibration (means its epoxy filled) would be my choice.
If you want a better coil, but its not a can, then get an "e-coil" the ones that sorta look like transformers
Re: need a coil recomendation [Re: Pacnorthcuda] #1247591
06/09/12 01:04 PM
06/09/12 01:04 PM
tboomer Offline
tboomer  Offline
Good stuff here about the MSD coil...
http://classracer.com/classforum/showthread.php?t=36302
Re: need a coil recomendation [Re: tboomer] #1247592
06/09/12 05:39 PM
06/09/12 05:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
interesting read and there's no question that an e-coil is the way to go but for a stock appearance, no dice. that and i don't think most of us would really ever notice the drop in performance. i got the impression the guy was just trying to push high $ stuff? i don't know, i'm not a bracket racer, just a 'poser'
Re: need a coil recomendation [Re: 1970sixpak] #1247593
06/09/12 06:09 PM
06/09/12 06:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Bingo!! But the production Rev N Nator works well with the MSD coils now.
The Accel coil does not do too well with the MSD6 on the dyno,I use a Blaster 3. I have tried the newer HVC2 coil from MSD on my dyno and under 7000 rpm with a 13 to 1 engine,the Blaster 3 did just as good. And it fits a stock bracket.
Keith
Re: need a coil recomendation [Re: Dunnuck Racing] #1247594
06/09/12 07:23 PM
06/09/12 07:23 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Keith
when you say HVC2 coil are you refering to the e-coil style boxy one or the e-filled can type that fits in the stock bracket (the one i posted a link to up above)? i'm curious how well they perform.... i would expect better due to no heat build up??
Re: need a coil recomendation [Re: mikemee1331] #1247595
06/09/12 10:15 PM
06/09/12 10:15 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
Thanks guys! The high vibe msd is the one I was leaning toward from my research. Thanks again ozz
Re: need a coil recomendation [Re: mikemee1331] #1247596
06/10/12 12:10 AM
06/10/12 12:10 AM
Northern Indiana
Northern Indiana
The HVC 2 I referred to was number 8253(the big blue U-core design).
It was designed for the MSD 6 ignitions,but requires different mounting locations or a custom bracket.
The only real advantage to it I see is possibly better high rpm spark. The engine I was dynoing with was past it's peak before 7000 rpm so it might help above that,hard to say without testing the right engine.
Keith
