Can I remove 426 Hemi heads in car (70 Challenger)? #1247413
06/08/12 05:32 PM
06/08/12 05:32 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I developed a miss in #7 cylinder in my 426 hemi. I did a leak down and I'm leaking pretty badly from #7 intake valve.
I would like to pull both heads for further examination because I also found a slight bend in #6 intake pushrod.
Can I remove the heads from the engine while its in the car. I'm mulling over how to handle the head studs that are fastened with nuts inside the valley area.
I don't think I have clearance to remove the head with the stud in it. Can the stud easily be backed out from the valley area? Is there enough room to disengage it from the head that way?
Thanks in advance
Tom
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247414
06/08/12 05:40 PM
06/08/12 05:40 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247415
06/08/12 05:47 PM
06/08/12 05:47 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Short answer: yes
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247416
06/08/12 05:48 PM
06/08/12 05:48 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Long answer: Yes! Assuming everything is in the stock location. You don’t need to worry about taking the valley studs off either. Passenger side is close though.
Good luck with finding your issue!
This post is available in double vision where drunk.
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: bwdst6] #1247417
06/08/12 06:21 PM
06/08/12 06:21 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Thanks Guys, I'll be giving it a shot next week. I'll let you know how I make out
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247418
06/08/12 07:48 PM
06/08/12 07:48 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
should come right out. If it gets close, try putting a wooden block under the oil pan and then lift the passenger side up a bit.
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: VanishPt] #1247419
06/08/12 09:27 PM
06/08/12 09:27 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Good idea, will do if needed
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247420
06/09/12 11:51 PM
06/09/12 11:51 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I know in our challenger there is no way the head on passenger side will come out with motor mount bolted and not sure even if it was undone and rocked over heck the valve cover wont even come off unless motor rocked over
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247421
06/10/12 12:21 AM
06/10/12 12:21 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Yes, it will come out..
plan on raising the engine on at least the passenger side, I would pull both side engine mount bolts..
Be prepared, wear a cup or your jewels may need to be repaired as well.. those Iron Hemi heads are heavy..I just got mine back from the machine shop...
Two people lift would be a good idea..
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: sthemi] #1247422
06/13/12 02:38 PM
06/13/12 02:38 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Thanks for the replies Gentleman. They came right out without any problem and without removing the head studs.
I didn't even have to raise the engine.
But boy were they heavy
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247423
06/13/12 03:01 PM
06/13/12 03:01 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Also, not really common with a street hemi build but if the block/heads have been studded (as opposed to stock head bolts)you cant pull the heads in the car.
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Finoke] #1247424
06/13/12 03:02 PM
06/13/12 03:02 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Swap in a set of StageV's, that will fix the heavy issue.
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: astjp2] #1247425
06/13/12 03:55 PM
06/13/12 03:55 PM
Portage Wisconsin
Lou_Steger Offline
Lou_Steger  Offline
Portage Wisconsin
Are those studs threaded into the bottom of the head??
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: Lou_Steger] #1247426
06/13/12 03:57 PM
06/13/12 03:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes they would be .
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: ScottSmith_Harms] #1247427
06/13/12 04:55 PM
06/13/12 04:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Can be done, been there done that with a 472 HEMI with full head/rocker studs, passenger side does require undoing the mount and angling the engine over a bit to clear the shock tower,...done the same thing with a fully studded 472 HEMI in the 71-2 B body platform also,...PITA, but doable
Re: Can I remove 426 Hemi heads in car (70 Challenger)? [Re: DAYCLONA] #1247428
06/13/12 05:33 PM
06/13/12 05:33 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I bet that's about the time you consider studs with allen holes in the ends...
