516 cylinder heads for 426 street wedge question #1247372
06/08/12 02:39 PM
06/08/12 02:39 PM
USA
SSAAHemiFan Offline OP
USA
I'm restoring a 65 Street Wedge Satellite - Friend has a Set of 2406516 heads that are used.
What would be a fair price to offer him ?
Car is running fine with the 906's that are on it.
The rest of the engine is 100% correct. ( carb, air cleaner, valve covers, dist, exhaust manifolds, oil pan, etc.)
I would just "put these away " for the future.
Re: 516 cylinder heads for 426 street wedge question [Re: SSAAHemiFan] #1247373
06/08/12 02:49 PM
06/08/12 02:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Next to nothing, they are super common, low demand, and low performance as compared to the bigger valve castings that followed them (906, 915's, etc.). You can barely give them away at swap meets, $50.00 a pair is generous.
Re: 516 cylinder heads for 426 street wedge question [Re: SSAAHemiFan] #1247374
06/08/12 02:51 PM
06/08/12 02:51 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Do they have the 1.74 exhaust valve installed? If so, maybe $50-100... if not, forget it. In unported form they flow a little less than the 906, too.
The 906's are open chamber and the 516 is closed chamber. Your compression ratio will go up.
Re: 516 cylinder heads for 426 street wedge question [Re: DrCharles] #1247375
06/08/12 03:26 PM
06/08/12 03:26 PM
dogdays Offline
dogdays  Offline
They are cores for a head nobody much cares about. The only thing they have going for them is they are closed chamber. I bought my last pair of 906s for $25, those are worth less. I'd say he should give them to you, to be real. Those are the kinds of things left behind at swap meets. If it makes you feel better offer $20 but that's just because you're a nice guy.
R.
PS: If you can do your own porting those can work pretty well on a 300 hp style engine.
Re: 516 cylinder heads for 426 street wedge question [Re: dogdays] #1247376
06/08/12 03:40 PM
06/08/12 03:40 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
98% of the time with the MoPar crowd this will never happen.. they think the part is worth its weight in gold x 10
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 516 cylinder heads for 426 street wedge question [Re: DARTH V8Я] #1247377
06/08/12 04:31 PM
06/08/12 04:31 PM
USA
USA
Thanks everyone. I knew the value wasn't much.
He offered them to me but I want to give him something.
I'm not gonna run them. I'll put them away for the next owner.
Appreciate the responses
Re: 516 cylinder heads for 426 street wedge question [Re: SSAAHemiFan] #1247378
06/08/12 09:34 PM
06/08/12 09:34 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
1) They are worth more than scrap value due to the closed chamber design.
2) I made 325 REAR WHEEL HP doing low 13's at 106 mph in a 3600 vehicle. Definitely more than 300 hp.
Give the guy $25-$40, home port the bowls, gasket match the intakes, add the 1.74 exh. valve (w/hardened seats) and you will be pleasantly surprised.
What little you'll give up on top end, if any, you'll gain from better throttle response with better compression.
Re: 516 cylinder heads for 426 street wedge question [Re: Dean_Kuzluzski] #1247379
06/08/12 09:51 PM
06/08/12 09:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree that they can be lightly cleaned up and ported to make decent power, however that doesn't change the fact that they are still about the cheapest and least popular iron BB mopar head on the planet.
Re: 516 cylinder heads for 426 street wedge question [Re: ScottSmith_Harms] #1247380
06/08/12 11:40 PM
06/08/12 11:40 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I'm running 11's now on a set of 516's. I have a few other things to sort out and I should break the 10's. Not bad for crappy elcheapo heads....
Re: 516 cylinder heads for 426 street wedge question [Re: SSAAHemiFan] #1247381
06/09/12 12:24 AM
06/09/12 12:24 AM
AndyF Offline
AndyF  Offline
I toss all of the 516 heads that come into my shop into the recycle bin.
Re: 516 cylinder heads for 426 street wedge question [Re: AndyF] #1247382
06/09/12 01:35 AM
06/09/12 01:35 AM
I switch from a set of big valve 516 that Don Studley did for me years ago on a bracket 440 motor to a set of 906 with the same size valves and 4 CC smaller chambers and that car piked up .3 ET and almost 3.5 MOH, no other changes For hose that like them, have yoou looked closely at the end exhaust ports, did you see the HUMPS
Re: 516 cylinder heads for 426 street wedge question [Re: AndyF] #1247383
06/09/12 08:47 AM
06/09/12 08:47 AM
Holly/MI
Holly/MI
Sooooo, recycle would mean at least "scrap value"!! Technically, not totally worthless. I'm currently purging ALL my 902, 452 and 906's and can't get an e-mail, fax, text, PM or anything for them. Got a big metal pile going now.
It's a big hobby, plenty of room for everyone. Lots of guys don't have an Indy or Edelbrock budget, does this mean they can't play?? Or just stay under the radar of the elite.
Yeah, the heads are the redheaded stepchild of the Mopar big block foray. Even worse is the stuff before it (excluding Max Wedge of course) but those aren't as common. I did mine back in the mid-90's when I was starting a family. It ran good for what it was and I had fun.
The days of freshening an old shortblock out of the barn and putting some fresh homeported heads on to see how it runs aren't worth the time & hassle.
No big thing, just sayin'!
Re: 516 cylinder heads for 426 street wedge question [Re: Dean_Kuzluzski] #1247384
06/09/12 12:35 PM
06/09/12 12:35 PM
AndyF Offline
AndyF  Offline
I kept the 452 and 906 heads on the shelf for several years hoping to sell them for the magical $100 per pair that everyone always claims they are worth. Eventually I got rid of all of them for scrap value to.
People say these heads are worth money but nobody ever showed up with cash in hand to buy them so they went to the recycle yard.
Re: 516 cylinder heads for 426 street wedge question [Re: AndyF] #1247385
06/09/12 12:47 PM
06/09/12 12:47 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I agree they arent worth much.I did mine with 2.14 and 1.81 SS valves ,springs,etc.My machinist ported them some and they were at 450 HP.Put them on my kids 413 and went aluminum on my 440.Had almost 1100 in them when they were finished.Rocky
Chrysler Firepower
