Page 1 of 3 1 2 3
Dakota F-body swap - You there Poorboy? #1247308
06/08/12 12:51 PM
06/08/12 12:51 PM
MA
Greg55_99 Offline OP
MA
Gene (Poorboy), you were pretty good at talking me down a couple of years ago when I wanted to swap a Dakota frame under my F-body Volare. Good info. Thanks for that. However, you may need to talk me down again.
I’ll be picking up an aftermarket Dakota crossmember originally for a 53/56 Ford F100 pickup. It comes from Elpolacko over at Industrial Chassis. Anyway, this was the older version (there is an updated version available now I think). I understand I’ll have to “wrap” the Volare frame for strength in order to use it. Dimensions look pretty good too. It’s only .25”wider than the Volare frame rails. Should slide in pretty good. I’ve only got $350 into this. Any thoughts or ideas?
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247309
06/08/12 10:47 PM
06/08/12 10:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Elpolacko (I think his first name is Steve) is a great guy with lots more suspension experience then I will ever have. I suggest you contact him and seek his words of wisdom, he will not point you in the wrong direction.
He builds the kits and can tell you what you need to do, or not to do as far as your F body is concerned.
I will not pretend to know more then a guy like Elpolacko. Taking advice from him would be much better then accepting my thoughts with my limited knowledge.
I'm not afraid to speak up when I feel someone with little or no understanding wants to do something suspension related I think might be dangerous, but I'm smart enough to know when someone that knows more then me about a subject speaks, I should shut up and listen.
Please let us know what he thinks, and suggests, about the subject, I think we can all learn something here.
I do want to remind you, your F body does not have a frame in the front. You have a reinforced, 16 gauge (or maybe even 18 gauge), multiple piece, sheet metal box they call a frame. Gene
Re: Dakota F-body swap - You there Poorboy? [Re: poorboy] #1247310
06/09/12 10:06 AM
06/09/12 10:06 AM
MA
MA
Yet again, that sounds like some pretty good advice! I dropped him an e-mail a few years ago about his and, at the time, said it was doable. Looks like I'll need some specifics. I'll keep you posted.
I also remember, quite clearly, your info about the F-body "frame" and how thin it actually is. Woke me up for sure...
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247311
06/09/12 10:58 AM
06/09/12 10:58 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Greg, were you the one who also looked into a Lexus SC300/400 IFS? There was someone with a F body who was looking at a few options for IFS. I was looking for IFS options for a 68 Scout and ran across them. I ended up picking up a AMC Pacer IFS but it will need some modifications to fit so I'm still deciding what I'll do.
What are with widths where I made the Red lines on your picture? See attachment, my pictures never show up here.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Dakota F-body swap - You there Poorboy? [Re: Soopernaut] #1247312
06/09/12 11:10 AM
06/09/12 11:10 AM
MA
MA
Oh yeah, that was me. I'd looked into a LOT of options in an effort to replace the torsion bar setup in my Volare. Lexus Sc300\400 was actually a good fit, but, it required quite a bit of fabbing to get coilovers in. Threw that one out. I'll be getting the crossmember on Monday so I can give you some measurements then. I did, however, ask the gent I bought it from to send me some dimensions. Here's the text:
"Hi Greg,
I have the dimensions you requested. As you probably know, the Ford F-100 frame rails taper, narrower toward the fron, therefore the side or boxing plates also taper as to their spacing.
Note: all dimensions below are outside to outside
Using your photo, dimension line "A", at the specific point, where the leading edge of the crossmember attaches to the side plate, the width is 29 9/16"
At the leading (front) edge of the boxing plate the width is 29 3/8"
At the rear edge of the center crossmember to side plate the width is 29 7/8"
At the back edge of the boxing plate the width is 30 1/8"
The overall length of the side plate, tip to tip at the top is 21 9/16"
So, there is 3/4" taper of the side plates over their length
________________________________________________________________________
Dimension "B"
Spacing from side to side at centerline of "A" arm anchor bolt hole appears to me to be 25 3/4"
Ray"
So far, that's what I know.
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247313
06/18/12 07:53 PM
06/18/12 07:53 PM
MA
MA
I guess I'm not as crazy as I thought. Message from Elpolako:
"Steve wrote:
Hi Greg,
I think it would be plausible to do. You could trim down the boxing plates of my old kit there to more resemble the “rails” in your car, then I would clad the other three sides of the rails to make a box section."
Sounds like my own line of attack.
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247314
06/18/12 10:37 PM
06/18/12 10:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Sounds like the plan is to make a box/tube over top of your existing "frame" (clad the other three sides) and adding the cross member. Steve says it should work, so it sounds like a plan to me. Did he say how far you should go with the clad plating, as in, how far in either direction from the cross member?
Keep us posted on the progress. Gene
Re: Dakota F-body swap - You there Poorboy? [Re: poorboy] #1247315
06/20/12 12:46 PM
06/20/12 12:46 PM
MA
MA
Hi Gene,
No, he didn’t say, but, I’ll ASSUME it’s best to clad BACK to the F-body transmission crossmember and weld frame connectors in at that point to tie everything together. I’ll also ASSUME it’s best to go as far forward as possible (at least to where the bumper bolts to the chassis. That’s the plan… Also, looking closely at the F-body rails, it looks like the sheet metal is lipped together and spot welded (is this clear?). I suspect I’ll have to cut off the protruding lip portion and seam weld it together. That will make it smoother for cladding.
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247316
06/20/12 11:52 PM
06/20/12 11:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Hi Gene,
Greg
Greg, Your plan sounds correct, the "frame" is spot welded together at the lip. I would cut one side at a time, and clad it as you go. Once one side has been joined with the top and bottom, then cut off the other flange and clad it.
I think I would also make sure your trans crossmember is secure to the rails when you get done. I dirt track raced an F body years ago and was side swiped by another car that was going faster then I was. When that car caught the front bumper, it pulled the frame rail away from the transmission crossmember, the factory welds were very poor. Understand, that F body was very rusty, but the condition of the metal surrounding that joint at the cross member was fairly good condition with bad spot welds. I simply would not rely on the factory spot welds at the rail to crossmember joint.
Gene
Re: Dakota F-body swap - You there Poorboy? [Re: poorboy] #1247317
06/29/12 12:00 PM
06/29/12 12:00 PM
MA
MA
Well, I just threw another 700 bucks at this project.... Putting my money where my mouth is....
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247318
06/29/12 09:52 PM
06/29/12 09:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So, enlighten us unacknowledged, what car is the rear suspension originally from? Is that a Jag? Gene
Re: Dakota F-body swap - You there Poorboy? [Re: poorboy] #1247319
06/29/12 10:48 PM
06/29/12 10:48 PM
MA
MA
That is from a 2003 Cobra. Found it on Craigslist locally. Has 22K miles on it, limited slip, aluminum housing with 31 spline axles. Owner swapped in 4.10 gears then went to a solid rear axle. Width is just at 61" rotor face to rotor face. F-body is just a hair under that. For seven bills, I just couldn't say no....
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247320
06/30/12 06:49 AM
06/30/12 06:49 AM
moparx Online content
moparx  Online Content
cobra as in mustang ? how much does that assembly weigh ? is it a weld/bolt in sorta deal ? how big are the axle shafts and bearings ? will the rear wheels need a strange backspace offset to fit decent size tires in the f body ? ring gear size ? sorry for all the questions. just curious
Re: Dakota F-body swap - You there Poorboy? [Re: moparx] #1247321
06/30/12 05:32 PM
06/30/12 05:32 PM
MA
MA
1. Yes, that is from a 2003 Mustang Cobra.
2. I don't know how much it weighs, but, it took myself and the gent that sold it to me to muscle it up into his truck. I'm sure that info is on the web somewhere.
3. Don't have a reading on the axle shaft size and bearings. That's probably out there as well.
I CAN tell you that the 2003-2004 version of this IRS are the best ones. They have the 31 spline shafts. The earlier versions had 28 splines.
4. No, no special backspacing looks like it will be needed in my F-body. I currently have a 69 B-body 8 3/4 housing in my Volare. The Cobra IRS is less than 1/2" wider.
5. The IRS uses the standard Ford 8.8" ring gear but with an aluminum housing.
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247322
07/08/12 01:01 PM
07/08/12 01:01 PM
MA
MA
Quick question Gene. Do you know if the F-body "frame" rails the same gauge as the A or B body?
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247323
07/09/12 12:36 AM
07/09/12 12:36 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Greg
Greg,
I can't say for sure they are the same gauge, (I have not put a thickness gauge to any of them) but I'm betting they are very close.
Keep in mind, Mopar often doubled (as in used 2 pieces of) metal in high stress areas and spot welded them together. Areas around body mount bolts may have 2 pieces of "frame" gauge metal spot welded together as well as an extra piece that could be as thick as 3/16" that had threads cut into it, I call a nut plate. If the nut plate had movement (most did), there would also had been a a shell casing to hold the nut plate in position spot welded around the edges, making as many a 4 pieces of sheet metal in some bolt on locations. Usually, any reinforcing in the frame rails was between 4" and 6" in length and would extend across the top (or bottom) of the rail and as much as 1/2" down both side rails on a top mounted reinforcing plate (or up both side rails on a bottom reinforcing plate). I sure wish I had pictures of all this stuff I could post up. Most frame rails were in the 16 gauge range.
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247324
07/09/12 07:00 AM
07/09/12 07:00 AM
St Louis,Mo
Hunkajunk79 Offline
Hunkajunk79  Offline
St Louis,Mo
I'd love to hear more about this Dakota F body swap,is there some info somewhere on it? I googled it and nothing came up except for older pickups.I will never have $5k for an aftermarket K,but we have tons of Dakotas in the local yards.
Thanx
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety. Benjamin Franklin, US author, diplomat, inventor, physicist, politician, & printer (1706 - 1790)
Re: Dakota F-body swap - You there Poorboy? [Re: Hunkajunk79] #1247325
07/09/12 12:05 PM
07/09/12 12:05 PM
MA
MA
You won’t find anything specific to the F-Body because no one has done it (that I know of). The Dakota cross member I’m using comes from Industrial Chassis in Phoenix. It’s for swapping the Dakota IFS into an older Ford truck. The specific unit that I have is actually no longer being produced by IC. I got lucky and found it through a HAMB guy. IC IS making new and improved units now however (also for Ford trucks). Check them out…
http://www.industrialchassisinc.com/Web-blog/?cat=5
I think the price is $795.
Greg
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247326
07/09/12 10:52 PM
07/09/12 10:52 PM
St Louis,Mo
Hunkajunk79 Offline
Hunkajunk79  Offline
St Louis,Mo
Re: Dakota F-body swap - You there Poorboy? [Re: Greg55_99] #1247327
10/08/12 05:36 PM
10/08/12 05:36 PM
United States
swisswill Offline
swisswill  Offline
United States
Bringing this back up. First, how is the project coming, any progress? Second, I'm looking at picking up an F-body wagon and doing a front clip with a tri-4 or Mustang IRS in the rear. Curious if you can give me a couple measurements off the front of your F-body as I research this. I'm looking for the outside to outside frame rail measurement and also the stock hub to hub measurement. I haven't been able to find anything on my searches yet. Thanks, and good luck!
Will Ellis 1969 Dodge Dart Swinger, 1/2 Dart, 1/2 Viper
Page 1 of 3 1 2 3
