440 stroker, what oil pan to use? #124675
09/22/08 06:12 PM
09/22/08 06:12 PM
NC
rickmoore69 Offline OP
NC
Putting the engine together with a 4.15 crank. Have a 402 oil pan but it looks like the back half of the oil pan is hitting the stroker windage tray and needs about another 1/4-1/2" for it to sit flat on the block. Need some input from someone that's put a stroker together as far as what oil pan do you use? Will a deeper pan in the back interfere with the steering link?
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124676
09/22/08 06:25 PM
09/22/08 06:25 PM
AndyF Offline
AndyF  Offline
Lots of oil pans should fit just fine with 4.15 stroke. Milodon has several street pans that should fit. Mancini Racing has a few reproduction type pans that should fit with the Street Hemi pan being a good choice.
Did you use Mopar sized rod journals? If so, you might need a stroker windage tray. The standard windage try works fine when using BB Chevy connecting rods on 4.15 or 4.25 stroke cranks.
Re: 440 stroker, what oil pan to use? [Re: AndyF] #124677
09/22/08 08:19 PM
09/22/08 08:19 PM
IN
ahy Offline
ahy  Offline
IN
I've had good results with the repop Hemi pan from Mancini. It picks up some needed capacity without being too low or expensive.
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124678
09/22/08 08:29 PM
09/22/08 08:29 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I use a Milodon in mine with the 4.15 crank.
This is the land of the free because of the brave
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124679
09/23/08 01:28 AM
09/23/08 01:28 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
I've got the Moroso 8 qt. and the 440Source stroker windage tray. Fits great!
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 440 stroker, what oil pan to use? [Re: 67Charger] #124680
09/23/08 10:41 AM
09/23/08 10:41 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Charger uses the Milodon low profile oil pan with 1/2" pickup. This engine will rev 7,000 RPM. It fit fine before on the old engine, but does hang down below the K-Member a bit. Now that the new engine has the stud girdle I will have to re-check the clearances.
The Coronet has the reproduction Hemi oil pan. It sits about flush with the K-Member. It easely clears the stock windage tray, but I'm not sure about the stroker windage tray? I like this oil pan for street driven cars that don't rev over 6,000 RPM.
I will check the Hemi Oil pan / 440 source stroker windage tray combination tonight as I have an extra of each sitting on the shelf.
Re: 440 stroker, what oil pan to use? [Re: 451Mopar] #124681
09/23/08 12:44 PM
09/23/08 12:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the 8 qt Moroso pan also. I like it as it fit fine in my 63 with the eng in the stock location and it has plenty of road clearence. Ron
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124682
09/29/08 08:06 AM
09/29/08 08:06 AM
NC
NC
Thanks for the input guys, does anyone have a part number? There are several mentioned and a bunch to choose from, want to make sure I get one that fits.
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124683
09/29/08 09:25 AM
09/29/08 09:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you never said what car you are putting the engine in , can't really give a good recommendation without that little tidbit of information .
Re: 440 stroker, what oil pan to use? [Re: JohnRR] #124684
09/29/08 06:40 PM
09/29/08 06:40 PM
NC
NC
Whoops, my mistake, 69 Roadrunner
Re: 440 stroker, what oil pan to use? [Re: rickmoore69] #124685
09/29/08 07:53 PM
09/29/08 07:53 PM
JohnRR Offline
JohnRR  Offline
if it's going to be a mostly street driven car do yourself a favor and run the 6qt mopar 70-71 hemi pan , plenty of gruond clearance and it will clear that tray .
