Re: Close call, almost lost my trailer and Cuda on the way [Re: Guitar Jones] #1246289
06/06/12 09:21 PM
06/06/12 09:21 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Its hard to identify.. but I just took a pic of my stock hitch on the 06 2500 Ram..
It has a large round pipe running from frame rail to frame rail.. and the actual hitch is welded to it..
Re: Close call, almost lost my trailer and Cuda on the way [Re: Jeepmon] #1246290
06/06/12 09:23 PM
06/06/12 09:23 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I have the same hitch as jeepmom
Re: Close call, almost lost my trailer and Cuda on the way [Re: WadeMetzinger] #1246291
06/06/12 09:39 PM
06/06/12 09:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Wouldn't catch me using that to tow 10K!!!
Are you towing with a 2003 - 2008 Dodge 3/4 ton, take a look, I bet it's what your towing with.
But I agree, I would rather it be a 1 piece hitch.
I've been using this to two 10,000lb trailer since 2004, many many miles.
You made me go look at my 08 2500 Ram.
The hitch is welded to the tubular piece that bolts to the frame on mine. I have the factory towing package with a Cummins 6.7 FWIW
Glad you found it before it was too late.
Re: Close call, almost lost my trailer and Cuda on the way [Re: Bigcube] #1246292
06/06/12 10:06 PM
06/06/12 10:06 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I work at the dodge dealer and what he has is a add on at the dealership. I have put a flew of them on and I thought they was rated for 5000lb. no way I would pull my 10000lb trailer with it !
Re: Close call, almost lost my trailer and Cuda on the way [Re: WadeMetzinger] #1246293
06/06/12 10:19 PM
06/06/12 10:19 PM
PA
70HemiGTX Online content
70HemiGTX  Online Content
PA
No I have a '95 3500. Class 5 hitch. No possible way for flex or anything with that piece. The outsides of the receiver rest against the spring perches. It was a tight fit between them. Also added an extra metal brace on each side that was supplied in the hitch kit.
Re: Close call, almost lost my trailer and Cuda on the way [Re: 70HemiGTX] #1246294
06/06/12 11:11 PM
06/06/12 11:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
95 to 03.... apple, meet orange. There is so much differance between those two builds we might as well have someone throw an opinion of a toyota in too for the mix.
Re: Close call, almost lost my trailer and Cuda on the way [Re: J_BODY] #1246295
06/06/12 11:27 PM
06/06/12 11:27 PM
Amherst,NY
challengermike Offline
Amherst,NY
I have had both the bolt on and the one piece hitches. The only difference i see is the one is welded on every where the other one bolts. The pic in the first post just shows the part that would bolt on if it didnt have a factory hitch. The big round tube that goes from frame rail to frame rail is on all the rams trailer package or not. I dont know what tow rating is but i dont think they are rated for 10k, i thought it was around 5k and with a weight distrubtion hitch it was 7,5k.
Re: Close call, almost lost my trailer and Cuda on the way [Re: challengermike] #1246296
06/06/12 11:38 PM
06/06/12 11:38 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
towing weight didn't do that, tongue weight did. trailers need to be scaled and set up properly.
But that over the counter dodge bolt on hitch you had was the same as i added to my 1/2 ton daytona and it was only rated at 5K towing with a 500 lb tongue weight.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Close call, almost lost my trailer and Cuda on the way [Re: bigtimeauto] #1246297
06/06/12 11:50 PM
06/06/12 11:50 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Here is what was added to your truck from the dealer:
https://www.dodgeparts.com/product_info....122f3659cc43726
Hitch 2003-2008 (Part Number-82207911AB)
Click to enlarge
Designed as a one-piece welded assembly for added strength, Mopar's Hitch Receivers match your vehicle's towing capacity. Covered with two-layered E-coated paint finish to resist rust. Features a 5,000-lb tow rating, 500-lb tongue weight rating, 2.0" opening
Note: (for trucks built After November 2002 Check your door sticker for the build date . Hitch for 2003 built before november 2002 is listed on the site as 2002 .Not for SRT-10)
Fits Model: Ram Truck
Fits Model Year(s): 2003-2008
Price: $123.60
Current Reviews: 7
This product was added to our catalog on Tuesday 31 December, 2002.
Re: Close call, almost lost my trailer and Cuda on the way [Re: bigtimeauto] #1246298
06/07/12 12:06 AM
06/07/12 12:06 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
You are right, mine was added at the dealership but the sticker on it out of the Mopar box said 1,200 tongue and 12,000 tow capacit, I'll shoot a picture of it tomorrow.
Rt66jim works as a doge dealership as a parts manager and had him look it up for me in case i couldn't get mine fixed and he found the part number and verified
It was rated at 1,200 and 12,000lbs WDH.
But I agree with you guys, I'll be ordering a real class V hitch when I get back. I'm heading out tomorrow for Monster Mopar at 7am or I would do it this weekend. I feel confident that it will make this trip, repaired and braced so better than it was and it has lasted 155,000 miles and a lot of those were towing my trailer.
Re: Close call, almost lost my trailer and Cuda on the way [Re: WadeMetzinger] #1246299
06/07/12 12:29 AM
06/07/12 12:29 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have the same "hitch" on my 2002 Ram quad cab.It's a Draw Tite and says I can tow 10K with it.I only have 5500# loaded,I tow the Demon and a open trailer but I think I'll switch the hitch.I have been using it for 10 years now with no problem.
Nautilus Racing-
Re: Close call, almost lost my trailer and Cuda on the way [Re: Chris2581] #1246300
06/07/12 12:55 PM
06/07/12 12:55 PM
sg66mopar Offline
sg66mopar  Offline
Wade, the factory cross tube on your truck in NOT intended to be removed. Your truck has the "dealer" installed hitch, where they just bolt up the center section rather than welding it at the factory.
The center section can be removed to install a B&W unit or Torklift SuperHitch.
Here's some links for you to look at BEFORE you remove your factory hitch.
I have the Torklift SuperHitch installed with the Dodge "Factory" hitch on my 03 Dually.
http://www.towshop.com/store/pc/viewPrd.asp?idproduct=8&idcategory=2
http://www.towshop.com/bw-25211-hitch-install.pdf
http://www.towshop.com/D1101-superhitch-installation-instructions.pdf
Re: Close call, almost lost my trailer and Cuda on the way [Re: sg66mopar] #1246301
06/07/12 03:48 PM
06/07/12 03:48 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
The rear frame rails and the crosstube on all RAM TRUCKS from 2002(DR mdl) and up. Have hydro formed frame rails and are not to be welded on as per Chrysler.
Re: Close call, almost lost my trailer and Cuda on the way [Re: Jeepmon] #1246302
06/07/12 04:21 PM
06/07/12 04:21 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Same setup as my 2003 2500
Rich H.
Esse Quam Videri
Re: Close call, almost lost my trailer and Cuda on the way [Re: ZIPPY] #1246303
07/14/12 02:38 PM
07/14/12 02:38 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Just got a good look at mine. Same rig and there are several places around the reciever that are not welded that could have been to make it stronger. I'll be working mine over!
Yeah, it's got a smallblock.
