quick,easy,inexpencive tank cleaning-possible? #1246241
06/06/12 03:00 PM
06/06/12 03:00 PM
Springfield Oregon
badblubeee Offline OP
super gas
super gas
Springfield Oregon
I need to clean lite to medium surface rust out of a gas tank.I don't believe it will need coating,just cleaned.I would like something that will clean but not leave any flakey residue.
Am I dreaming? I've heard of muradic acid from home inprovement stores but no detales.
Any suggestion? Thanks, Dave
Re: quick,easy,inexpencive tank cleaning-possible? [Re: badblubeee] #1246242
06/06/12 03:09 PM
06/06/12 03:09 PM
Andrewh Offline
Andrewh  Offline
muraic acid does work. you need to throw something inwith it like nuts and bolts to scrub the inside.
BUT, 2 things. First, getting rid of the nasty stuff that comes out is going to be hard.
It will stain concrete. and I tried neutralizing it and was left with rusty sludge in a can. I threw it away after I was sure it woudn't react, but not sure what else is in it.
second, the tank will be raw metal inside again. so some sort of coating will be necessary to prevent rusting again.
Re: quick,easy,inexpencive tank cleaning-possible? [Re: Andrewh] #1246243
06/06/12 03:29 PM
06/06/12 03:29 PM
P
Paul_Fancsali Offline
P
Try E-85 if its available. 2-3 go=allons of that crap seems to ruin everything else if its not stainless
Re: quick,easy,inexpencive tank cleaning-possible? [Re: Andrewh] #1246244
06/06/12 04:16 PM
06/06/12 04:16 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
I have used diesel and gravel before and hauled a tank around in the back of the pick up for a couple weeks but it was a piece o' junk and turned into a screen door and I agree about E 85.Sounds like I'm left with POR 15 treatment just hoping for something less involved.
I tried local radiator shops for a dunk and that's a no go.And the local metal dip place wants $100.poot
Re: quick,easy,inexpencive tank cleaning-possible? [Re: badblubeee] #1246245
06/06/12 04:30 PM
06/06/12 04:30 PM
Andrewh Offline
Andrewh  Offline
see if you can find an ecoat place near you.
they have big tanks to remove rust.
not that expensive for the ecoat either.
Re: quick,easy,inexpencive tank cleaning-possible? [Re: Andrewh] #1246246
06/06/12 07:20 PM
06/06/12 07:20 PM
IN
ahy Offline
ahy  Offline
IN
I have used the 3 step Eastwood tank clean and coat system with good results. Strong detergent, acetone, acid and sealer. After using the acid I poured it in a plastic bucket with limestone gravel. Left it there for a day or two then dumped it out.
Agree after acid cleaning, a coating would be important.
From a cost (time and money) a new tank wouldn't be much more expensive but the old tanks and sending units seem to have less problem with sealing and guage accuracy so saving yours probably makes sense.
Re: quick,easy,inexpencive tank cleaning-possible? [Re: ahy] #1246247
06/06/12 07:52 PM
06/06/12 07:52 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
A new tank is the easiest and the least amount of trouble...
Re: quick,easy,inexpencive tank cleaning-possible? [Re: sixpack4spd] #1246248
06/06/12 11:11 PM
06/06/12 11:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd like to hear the list of car related things that are
1. Quick
2. Easy
3. Cheap
'cause I'm ready to buy!
Re: quick,easy,inexpencive tank cleaning-possible? [Re: RodStRace] #1246249
06/07/12 12:17 AM
06/07/12 12:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1. Quick
2. Easy
3. Cheap
Re: quick,easy,inexpencive tank cleaning-possible? [Re: RodStRace] #1246250
06/07/12 12:22 AM
06/07/12 12:22 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
1. Quick
2. Easy
3. Cheap
Little tree air freshners ?
Re: quick,easy,inexpencive tank cleaning-possible? [Re: OzHemi] #1246251
06/07/12 09:08 AM
06/07/12 09:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
At least 15 years ago I did my tank in the 65.It was nasty.I used the POR15 kit.I did the first step the acid.Let it set for a day while turning the tank and shaking it.Then cleaned it out and it sat for 2 days in the sun.Then sealed it and that sat fir 2 days in the hot sun.Still looks like the day I did it.It was cheap easy and worked like a charm.The tank is better than new.Just follow the directions.I think at the time it was around 20 bucks.Rocky
Chrysler Firepower
Re: quick,easy,inexpencive tank cleaning-possible? [Re: therocks] #1246252
06/07/12 09:22 AM
06/07/12 09:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When was the last time you peeked inside it ? How often have you looked inside in the past 15 yrs ?
Re: quick,easy,inexpencive tank cleaning-possible? [Re: OzHemi] #1246253
06/07/12 09:25 AM
06/07/12 09:25 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
1. Quick
2. Easy
3. Cheap
Sometimes they are even sent to you for free with your favorite scent!
Re: quick,easy,inexpencive tank cleaning-possible? [Re: moparpollack] #1246254
06/07/12 10:52 AM
06/07/12 10:52 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
1. Quick
2. Easy
3. Cheap
French hooker?
Scott
1969 Super Bee, 383/4 speed
Re: quick,easy,inexpencive tank cleaning-possible? [Re: RodStRace] #1246255
06/07/12 11:05 AM
06/07/12 11:05 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
1. Quick
2. Easy
3. Cheap
You can have any TWO of the above
I also recommend the POR-15 kit. Yes, it's time consuming with the clean, soak, rinse, and especially the tank has to be BONE DRY after rinsing! I usually duct-tape an old hair dryer to the neck and let it run on low heat all day. Then put the sealer in.
I've used that kit on at least four car/truck/tractor gas & diesel tanks with success. The oldest is at least 12 years and still no problems with peeling or re-rusting.
