Air testing a 727 #1246153
06/06/12 11:28 AM
06/06/12 11:28 AM
Finally a HUSKER again
Moparnut426 Offline OP
So Im still diagnosing the 727 in the Ramcharger. I dont think I have any major issues, I think it is all in the VB. I can air test it and EVERYTHING holds air, and you cant hear any bleeding inside, it holds it and then puffs it back out to me when I pull the test plug out.
Is the round port basically under the torque converter the forward supply port? Thats the set I want to test, and when I do its fine.
Are there more than 4 holes to test with air?
Thanks guys
Re: Air testing a 727 [Re: Moparnut426] #1246154
06/06/12 12:31 PM
06/06/12 12:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
4 is pretty much all you can test with air , front and rear clutch , and the 2 servos .
Re: Air testing a 727 [Re: JohnRR] #1246155
06/06/12 12:48 PM
06/06/12 12:48 PM
COOL!! thats what I thought,
Well its sealed up good. So Im sure Its a VB issue.
The shuttle valve seems to not want to stay up against the kickdown lever. Its realy loose and I think its binding in there.
All grab another VB I have laying around and see what I can do.
Kasey
Re: Air testing a 727 [Re: Moparnut426] #1246156
06/06/12 12:50 PM
06/06/12 12:50 PM
JohnRR Offline
JohnRR  Offline
Shuttle valve does not stay out till the trans is pumping fluid .
Re: Air testing a 727 [Re: JohnRR] #1246157
06/06/12 01:55 PM
06/06/12 01:55 PM
Guitar Jones Online laugh2
Check the pressure relief valve it's under the big spring.
