Air testing a 727 #1246153
06/06/12 11:28 AM
06/06/12 11:28 AM
Finally a HUSKER again
Moparnut426 Offline OP
So Im still diagnosing the 727 in the Ramcharger. I dont think I have any major issues, I think it is all in the VB. I can air test it and EVERYTHING holds air, and you cant hear any bleeding inside, it holds it and then puffs it back out to me when I pull the test plug out.
Is the round port basically under the torque converter the forward supply port? Thats the set I want to test, and when I do its fine.
Are there more than 4 holes to test with air?
Thanks guys
Re: Air testing a 727 [Re: Moparnut426] #1246154
06/06/12 12:31 PM
06/06/12 12:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
4 is pretty much all you can test with air , front and rear clutch , and the 2 servos .
Re: Air testing a 727 [Re: JohnRR] #1246155
06/06/12 12:48 PM
06/06/12 12:48 PM
COOL!! thats what I thought,
Well its sealed up good. So Im sure Its a VB issue.
The shuttle valve seems to not want to stay up against the kickdown lever. Its realy loose and I think its binding in there.
All grab another VB I have laying around and see what I can do.
Kasey
Re: Air testing a 727 [Re: Moparnut426] #1246156
06/06/12 12:50 PM
06/06/12 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Shuttle valve does not stay out till the trans is pumping fluid .
Re: Air testing a 727 [Re: JohnRR] #1246157
06/06/12 01:55 PM
06/06/12 01:55 PM
Guitar Jones Online laugh2
Check the pressure relief valve it's under the big spring.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
