Fuel tank location rule question #1245587
06/04/12 10:36 PM
06/04/12 10:36 PM
Carstairs, Alberta, Canada
dave571 Offline OP
dave571  Offline OP
Ok.
I'm doing up a 49 fargo truck into a street rod.
I want to run it down the track, so I want to know if mounting one of those aluminum hot rod style tanks in the box, is legal.
I've got an older rule book, and can't find anything directly to the contrary in the general regulations, but the rules all seem to worded for cars, not trucks.
Any help appreciated.
Re: Fuel tank location rule question [Re: dave571] #1245588
06/04/12 10:52 PM
06/04/12 10:52 PM
There must be a fireproof firewall between the driver and the fuel tank, no matter where it is, front of the grill, in the trunk or in the roadster or truck bed Send NHRA a E mail(then you have the reply in writing ) or call NHRA tech to get the most current straight scoop What does a Fargo truck look like pictures speak way louder than ten thousand words
Re: Fuel tank location rule question [Re: dave571] #1245589
06/04/12 10:59 PM
06/04/12 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok.
Yes mounting it in the bed IS legal
Re: Fuel tank location rule question [Re: MR_P_BODY] #1245590
06/05/12 12:26 AM
06/05/12 12:26 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
thats a pickup so Yes you can mount a fuel cell in the bed and be legal
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Fuel tank location rule question [Re: bigtimeauto] #1245591
06/05/12 06:18 AM
06/05/12 06:18 AM
Guitar Jones Offline
Just remember if the sump sticks through the floor it must be covered.
Re: Fuel tank location rule question [Re: Guitar Jones] #1245592
06/05/12 10:10 AM
06/05/12 10:10 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Also, if you run IHRA there is a rule on heigth. Ck the rule book.
Re: Fuel tank location rule question [Re: Blucuda413] #1245593
06/05/12 02:56 PM
06/05/12 02:56 PM
dave571 Offline OP
dave571  Offline OP
Thanks for the info Guys
Here's some pics
Re: Fuel tank location rule question [Re: dave571] #1245594
06/05/12 02:58 PM
06/05/12 02:58 PM
dave571 Offline OP
dave571  Offline OP
Front suspension is 04 crown vic. Rear is 4 link with 8 3/4"
Motor is a 400 BB I did some work to a few years back.
Re: Fuel tank location rule question [Re: dave571] #1245595
06/05/12 03:00 PM
06/05/12 03:00 PM
dave571 Offline OP
dave571  Offline OP
There is a startup video on you tube.
Search "Fargo Truck TV Episode 11"
or fargo truck tv epsiode 11
