Need a Mopar mechanic in NE Illinois #124550
09/22/08 03:13 PM
09/22/08 03:13 PM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
I have a 74 Fury (ex police car) with a 440 that I can't get running. I have done the basics but have run out of patience. I'm looking for someone to diagnose the problem and get the car running. Maybe some other mechanical repairs, also. Don't have a big budget, so am unable to take it to a commercial shop with their labor rates. PM me if you can help. I can tow the car to your location.
Thanks,
Steve
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124551
09/22/08 03:59 PM
09/22/08 03:59 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Steve,
I can suggest the person in the area who will know the most about what you are looking for. Contact
Larry at Mopar City. They are in Oregon, IL
If you do a web search you will find them, if not,
PM and I will send contact number.
Re: Need a Mopar mechanic in NE Illinois [Re: Dart 340] #124552
09/22/08 04:47 PM
09/22/08 04:47 PM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
Thanks. I called Mopar City but he didn't have anyone to recommend. He might have some body panels that I need, though.
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124553
09/22/08 05:27 PM
09/22/08 05:27 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Sorry, I thought he'd hook you up for sure.
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124554
09/22/08 07:33 PM
09/22/08 07:33 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Try Rhinodart, Jim Rhinehart,
He is in Round lake, IL,
He will have some leads for you.
Re: Need a Mopar mechanic in NE Illinois [Re: sthemi] #124555
09/22/08 07:37 PM
09/22/08 07:37 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Check out www.chicagolandmopar.com they have a forum there that you can help you out. I'd help ya out, but I'm busy with work and family health issues.
Where are you at?
Ryan
Re: Need a Mopar mechanic in NE Illinois [Re: Devil] #124556
09/22/08 08:02 PM
09/22/08 08:02 PM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
Where are you at?
Ryan
I'm in Naperville, but the car is stored in Yorkville right now. I tried signing on to the Chicagoland Mopar forum but it hasn't accepted my registration yet.
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: sthemi] #124557
09/22/08 09:37 PM
09/22/08 09:37 PM
He is in Round lake, IL, He will have some leads for you.
I have traded with him. He is a straight up guy.
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124558
09/22/08 10:52 PM
09/22/08 10:52 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Where are you at?
Ryan
Steve, Lived in Naperville many years.
I am thinking I might have a friend who can stop by for free but I need to talk to him before I volunteer his services.
Re: Need a Mopar mechanic in NE Illinois [Re: Dart 340] #124559
09/22/08 11:05 PM
09/22/08 11:05 PM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
Thanks.
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124560
09/23/08 02:50 PM
09/23/08 02:50 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Simple Q&A first...
does it turn over?
do you have spark?
do you have gas at the carb?
did you change the ballast resistor?
did you change the ignition control module?
did you advance the timing(incase the timing chain jumped)to see if it will start?
Re: Need a Mopar mechanic in NE Illinois [Re: Joesixpack] #124561
09/23/08 04:29 PM
09/23/08 04:29 PM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
Simple Q&A first...
does it turn over?
do you have spark?
-It turns over
-Don't know about spark, haven't had a helper to check while it turns over.
-new ballast resistor, new orange module, new plug wires, new cap & rotor
-carb rebuilt by demonsizzler, is getting gas to carb (new gas tank and fuel pump)
-haven't played with the timing, but dist rotor is turning and rocker arms are moving when engine turns over.
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124562
09/23/08 10:31 PM
09/23/08 10:31 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Steve,
Can you PM me your number so I can call you. I might
be in Naperville in the next week or so.
Re: Need a Mopar mechanic in NE Illinois [Re: Dart 340] #124563
09/24/08 10:59 AM
09/24/08 10:59 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
you can turn the key to ON,get out,remove the coil wire from the cap, ground it,ie lay it on metal, then take a screwdriver and cross the two posts on the starter relay and the starter will engage,it will turn over, then 1 person can check for spark....you should see a spark from the coil wire to the metal ground....
Re: Need a Mopar mechanic in NE Illinois [Re: Joesixpack] #124564
09/24/08 11:44 AM
09/24/08 11:44 AM
Illinois
SteveA Offline OP
SteveA  Offline OP
Illinois
Thanks for the tip, that's what happens when a Chevy guy buys a Mopar !
Steve
Re: Need a Mopar mechanic in NE Illinois [Re: SteveA] #124565
09/25/08 08:25 AM
09/25/08 08:25 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Let me know what you find....have good used test stuff, ie ignition module,resistor,etc...
