Re: Plz help me fine tune vacuume advance!
[Re: pjc360]
#1245145
06/04/12 02:18 AM
06/04/12 02:18 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Turning the screw does not increase or decrease the amount of advance.. All it does it adjust when the advance comes in..
I am truckless..
[Re: 340SHORTY]
#1245146
06/04/12 02:48 AM
06/04/12 02:48 AM
Posts: 3,892 Oregon
hooziewhatsit
Does it run well with the vacuum advance disconnected? If not, get that figured out first, and then and only then work on the advance.
And like shorty said, adjusting the screw only changes how much vacuum causes it engage. You'd have to take the cap off and find a way to limit/lengthen the travel to change how much advance it provides.
Ideally this is done with something like a mity-vac so you can apply measured vacuum at idle and see the 'curve', then adjust it accordingly.
[Re: pjc360]
#1245148
06/04/12 07:28 AM
06/04/12 07:28 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
There should of been instructions with the dist. If not call FBO to find out why not.. Your best bet would be to take it to a dist shop and have them set it up.
I am truckless..
[Re: abodyjoe]
#1245150
06/04/12 10:54 AM
06/04/12 10:54 AM
RapidRobert
Yes I would give Don a call 1st. Vac adv changes rotor phasing so you might check that too. Drill a 1/2" hole in the top flat of the cap 2/3 of the way between the center terminal and the terminal with the #1 plug wire on it & shine your timing light straight down onto the rotor blade at the offending rpm & see if it is pointed at or very close to the cap terminal. Can use a Mityvac to pull the can thru its' travel EDIT use a 3/32" allen wrench turning it 2 turns CCW at a time to reduce when the curve starts then take it out & try it & see if that helps
[Re: abodyjoe]
#1245151
06/04/12 12:24 PM
06/04/12 12:24 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
""hmmm. dropped my fbo dist in, set it to where the sheet said and it ran great. i would call FBO before you mess around and screw with the dist."" Me two. Since Don now sets up his distributors for manifold vacuum, you should probably go back to that or call Don. But I will give you some friendly advice before calling Don. As soon as you tell him that you are not hooking it up to manifold vacuum, he will be curious why. I did have to richen up my idle mixture once I got the distributor in and set correctly. With the extra timing at idle when the VA is hooked up to manifold vacuum, you may need to richen up your idle mixture to compensate for the extra timing. Note: Don said that this setup (manifold vacuum) requires 12" vacuum minimum (auto or manual) to keep the can happy. Once I had mine setup, my IN DRIVE (with brake applied) came out to right at 12"hg but the idle was too high. So I lowered the in D idle rpms down and I am now getting 11-1/2" hg minimum and the idle is still steady. I definitely would not try to run this distributor with less than this for a vacuum reading. I would guess that I am on the ragged edge of keeping the can happy.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: pjc360]
#1245152
06/04/12 01:22 PM
06/04/12 01:22 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Pretty simple get it running as good as you can with vacuum disconnected and plugged. get total where you want it and if it has enough idle advance to idle well in gear leave it and drive it a while. if it needs more idle advance work the curve till it does. Then after driving and your happy plug vacuum advance into ported vacuum and drive if it pings put a 3/32 allan wrench in through port and turn counter clockwise maybe 3 turns to start and drive then keep adjusting this way 1 turn at a time till any ping at light cruise is gone!
[Re: pjc360]
#1245156
06/04/12 08:44 PM
06/04/12 08:44 PM
RapidRobert
too much too fast-turn it CCW. At max vac you'll still have the same amt (total) but until then CCW will slow the onset
[Re: pjc360]
#1245159
06/05/12 02:46 AM
06/05/12 02:46 AM
Posts: 5,162 CT
GTX MATT
CT
No, do not get the desired total initial timing with vacuum advance by adjusting the advance can. Disconnect the vacuum advance and plug the port on the carburetor.
Now set your initial timing at 16 degrees.
THEN plug the vacuum advance in. It really doesn't matter exactly what the vacuum advance does for full throttle performance, but set it up how FBO advised. If it isn't 30 degrees once the vacuum advance is hooked up (to manifold vacuum) then adjust the vacuum advance can accordingly.
Your timing is probably a few degrees retarded of the recommendation from FBO.
Don't forget that idle speed and the timing will both effect vacuum at idle, and thus will effect how strongly the vacuum advance can be pulled. Make sure that the car is up to running temperature and that the idle speed is set where you want it with the advance hooked up to check your initial timing with the vacuum advance before you fiddle with the adjustment in the vacuum advance can.
EDIT: I may be misunderstanding what you did, but confirm that you set it up the way that I recommended.
[Re: pjc360]
#1245160
06/05/12 01:53 PM
06/05/12 01:53 PM
YO7_A66
Indiana
""If i'm reading 30 degrees at an idle with the vacuume advance plugged into full manifold vacuume then i must be sitting right at where don at fbo systems said it needs to be. "" It sounds like you have installed it correctly. Now you just need to tune your metering screws for the best vacuum reading in N (for manual tranny ), or best vacuum reading in D with brake applied (auto) and then take note of your vacuum reading to make sure that it is above the 11.5-12" reading. If so, then you are good. Note: The engine needs to be at full operating temp "before" this final tuning process.
