Re: What brand of wrinkle finish on 71 340 Air Cleaner?
[Re: Chal340]
#1244538
06/03/12 05:17 AM
06/03/12 05:17 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Get the air cleaner hot, like 200-250 degrees in a oven. Then put a cover coat. Back in oven at 150-200 for 10-15 minutes. Then final coat or repeat once more. Doesn't need thick coats. Then bake for 1 hour at 150-200 degrees. Will look very uniform and will be VERY durable. Way more uniform that factory. Factory had runs and not uniform coverage. The run in this valve cover it because I put a coat on too thick. Next run I experimented with multiple very thin distant fog coats on that air cleaner top. That was over reacting and got paint everywhere . I got less wrinkle and more of a uniform textured look. Best technique was in between both those ideas with the same looking results as the distant fog coats. [image][/image]
[Re: wally426ci]
#1244544
06/03/12 01:23 PM
06/03/12 01:23 PM
Posts: 83 CT
1932chrysler
CT
I used the VHT wrinkle plus but you dont have to put it in the oven apply 3 even heavy coats then put the parts out in the sun and watch it wrinke then bring it inside done if the parts are preped takes about 1/2 hour to do
1932 Chrysler CI Sedan 1956 Pontiac Catalina Sedan All Makes & Models Are Special
[Re: ScottSmith_Harms]
#1244545
06/03/12 02:08 PM
06/03/12 02:08 PM
Posts: 75,003 U.S.S.A.
JohnRR
U.S.S.A.
Powder coating has it's place and looks great, however it does not result in a 100% factory appearance, mainly because a powder coated finish is too even where as a painted part is less even and more blotchy between smooth and wrinkled areas. Also, if you have ANY dings, scrapes, or other imperfections they WILL show through powder coating, same goes for the paint but to a lesser degree than powder coat.
Scott in the day of concours incorrect over restoration I would have thought that the overdone look of powdercoat would be welcomed ???
[Re: JohnRR]
#1244546
06/03/12 02:26 PM
06/03/12 02:26 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Welcomed by who? I am not part of that "concours incorrect over restoration" crowd so I guess I missed your point?
#1244548
06/03/12 10:52 PM
06/03/12 10:52 PM
Posts: 3,821 New State
kidmopar
New State
The Harley Davidson brand works well for me
The H.D. Wrinkle black never occurred to me! GREAT IDEA! Thank You , Scott
[Re: kidmopar]
#1244549
06/03/12 11:24 PM
06/03/12 11:24 PM
autoxcuda
So Cal
We just did a 69 HiPo air cleaner today in my oven for Troy's 69 340 Swinger in Kylon wrinkle.
Maybe he will post pictures??
Heated oven to 170 degrees. Put air cleaner in for about 10-15 minutes. Sprayed a pretty decent wet coat of paint. Back in over for 15 minutes. Noticed some thin spots. Out of oven for 2nd coat put on all the way around. Back in over for 20 minutes.
He liked what he saw, so he took it out. Was nervous about it changing it's look if left longer. Personally, I think he should have left it in there for an hour. It would be fully dried by then and I think be more durable.
[Re: kidmopar]
#1244551
06/04/12 01:10 AM
06/04/12 01:10 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Talk about a small world....this is what Steve and I did today. Preheat oven to 170 degrees. Place part in oven for 5 to 8 min. Pull part out and apply a medium coat of paint on part. Place back in oven for 10 to 13 minutes. Pull part out of oven and apply second medium coat of paint on part. Place back in oven for 15 minutes. Let cool and your done. Last but not least.....don't let the wife find out that your cooking car parts in her oven.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1244552
06/04/12 01:11 AM
06/04/12 01:11 AM
Troy
West Coast, CA
.....Looks good and came out very even..
