What brand of wrinkle finish on 71 340 Air Cleaner? #1244535
06/02/12 11:21 PM
06/02/12 11:21 PM
Maryland
wally426ci Offline OP
Maryland
Challenger.
I used some auto parts store stuff 10 years ago and its pretty smooth now, just wondering what everyone is using to be fairly accurate?
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: wally426ci] #1244536
06/03/12 12:15 AM
06/03/12 12:15 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The Harley Davidson brand works well for me
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: ScottSmith_Harms] #1244537
06/03/12 05:08 AM
06/03/12 05:08 AM
FRANCE, Paris
Chal340 Offline
Chal340  Offline
FRANCE, Paris
I used VHT wrinkle black paint.
70 Challenger, A66, 340 ci
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: Chal340] #1244538
06/03/12 05:17 AM
06/03/12 05:17 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Get the air cleaner hot, like 200-250 degrees in a oven. Then put a cover coat. Back in oven at 150-200 for 10-15 minutes. Then final coat or repeat once more. Doesn't need thick coats. Then bake for 1 hour at 150-200 degrees.
Will look very uniform and will be VERY durable. Way more uniform that factory. Factory had runs and not uniform coverage.
The run in this valve cover it because I put a coat on too thick. Next run I experimented with multiple very thin distant fog coats on that air cleaner top. That was over reacting and got paint everywhere . I got less wrinkle and more of a uniform textured look. Best technique was in between both those ideas with the same looking results as the distant fog coats.
[image][/image]
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: wally426ci] #1244539
06/03/12 11:18 AM
06/03/12 11:18 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Check with a local powder coater.
Not that expensive and the results are awesome and very durable.
Jules
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: JulesdaWiperman] #1244540
06/03/12 11:59 AM
06/03/12 11:59 AM
Maryland
Maryland
Wow. Thanks for the responsses guys. I like the powder coat idea. I need to get a new lid if I am going that route.
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: wally426ci] #1244541
06/03/12 12:27 PM
06/03/12 12:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
On that stuff I ran in the oven, I can run my fingernail across it pressing down as hard as I can and not scratch the paint.
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: autoxcuda] #1244542
06/03/12 12:39 PM
06/03/12 12:39 PM
Yonkers N.Y
GTSfanatic Offline
GTSfanatic  Offline
Yonkers N.Y
I don't know about the OP. But my wife would scratch my eyes out if I cook car parts in her oven.
1968 Dart GTS 340 Auto...White, Red Int
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: autoxcuda] #1244543
06/03/12 12:45 PM
06/03/12 12:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Powder coating has it's place and looks great, however it does not result in a 100% factory appearance, mainly because a powder coated finish is too even where as a painted part is less even and more blotchy between smooth and wrinkled areas. Also, if you have ANY dings, scrapes, or other imperfections they WILL show through powder coating, same goes for the paint but to a lesser degree than powder coat.
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: wally426ci] #1244544
06/03/12 01:23 PM
06/03/12 01:23 PM
CT
1932chrysler Offline
CT
I used the VHT wrinkle plus but you dont have to put it in the oven apply 3 even heavy coats then put the parts out in the sun and watch it wrinke then bring it inside done if the parts are preped takes about 1/2 hour to do
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: ScottSmith_Harms] #1244545
06/03/12 02:08 PM
06/03/12 02:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott in the day of concours incorrect over restoration I would have thought that the overdone look of powdercoat would be welcomed ???
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: JohnRR] #1244546
06/03/12 02:26 PM
06/03/12 02:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Welcomed by who? I am not part of that "concours incorrect over restoration" crowd so I guess I missed your point?
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: ScottSmith_Harms] #1244547
06/03/12 05:35 PM
06/03/12 05:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm sure it would be welcomed by someone ???
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: ScottSmith_Harms] #1244548
06/03/12 10:52 PM
06/03/12 10:52 PM
New State
kidmopar Offline
kidmopar  Offline
New State
The H.D. Wrinkle black never occurred to me! GREAT IDEA! Thank You , Scott
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: kidmopar] #1244549
06/03/12 11:24 PM
06/03/12 11:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
We just did a 69 HiPo air cleaner today in my oven for Troy's 69 340 Swinger in Kylon wrinkle.
Maybe he will post pictures??
Heated oven to 170 degrees. Put air cleaner in for about 10-15 minutes. Sprayed a pretty decent wet coat of paint. Back in over for 15 minutes. Noticed some thin spots. Out of oven for 2nd coat put on all the way around. Back in over for 20 minutes.
He liked what he saw, so he took it out. Was nervous about it changing it's look if left longer. Personally, I think he should have left it in there for an hour. It would be fully dried by then and I think be more durable.
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: autoxcuda] #1244550
06/04/12 01:02 AM
06/04/12 01:02 AM
New State
kidmopar Offline
kidmopar  Offline
New State
I can just "see" my wife if I tried to stick an air cleaner in HER oven!
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: kidmopar] #1244551
06/04/12 01:10 AM
06/04/12 01:10 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Talk about a small world....this is what Steve and I did today.
Preheat oven to 170 degrees.
Place part in oven for 5 to 8 min.
Pull part out and apply a medium coat of paint on part.
Place back in oven for 10 to 13 minutes.
Pull part out of oven and apply second medium coat of paint on part.
Place back in oven for 15 minutes.
Let cool and your done.
Last but not least.....don't let the wife find out that your cooking car parts in her oven.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: Troy] #1244552
06/04/12 01:11 AM
06/04/12 01:11 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
.....Looks good and came out very even..
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: Troy] #1244553
06/04/12 01:13 AM
06/04/12 01:13 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Last one.
Re: What brand of wrinkle finish on 71 340 Air Cleaner? [Re: Troy] #1244554
06/04/12 01:15 AM
06/04/12 01:15 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Another tip....Once done painting and letting them cool off avoid letting any part of the painted surface to contact anything for at least a couple days, the paint takes some time to harden off and sometimes what seems cool/dry/cured, is actually still soft enough to take imprints from objects in contact with it, even really soft objects like packing bubble wrap, etc.
AMHIK!
