Chassis Flex #1244206
06/02/12 06:39 PM
06/02/12 06:39 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I have some movement under the car.
In 2010/October I was working on a goes left during a wheelstand issue. Finally figured out the wheeliebars topped-out at different heights and that steered the car LEFT.. It went 10.11/10.11/10.13/10.11 ,60fts varied .004 allday.
I was pretty proud to be that consistent with a 4-spd. All is well.
Fast forward to 2012 May-12th,1st time car has moved since the `2010 runs.Touched nothing-fuel/battery-turned the key.
Goes hard RIGHT
So I`m under it and find the ladder bar brackets on the right-side are buckled and cracked Left-side much less damage,but still visible.
Its old and beat up,so not too hard to swallow. But I have 2-in.s of tire clearance on each side and the drivers-side shows where it rubbed!!
I`ve layed under there and studied everything and can`t come up with a theory how the left side only could move that far,right-side is the worst damage-wise,but left let the tire move 2in`s???
Ideas???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Chassis Flex [Re: 6bblFLASH] #1244207
06/03/12 07:33 PM
06/03/12 07:33 PM
N.E. Ohio
N.E. Ohio
Think I found the problem. Thanks for all the replies
Re: Chassis Flex [Re: 6bblFLASH] #1244208
06/03/12 07:47 PM
06/03/12 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the right side moving forward that gives the car
rear steer... right side forward will drive the rear
of the car left and turns the front right... when you
have rear steer you have to look at things backwards
Re: Chassis Flex [Re: 6bblFLASH] #1244209
06/03/12 07:50 PM
06/03/12 07:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also... see if the right side is broke free... on
decell the right would drop back moving the left
side forward
Re: Chassis Flex [Re: 6bblFLASH] #1244210
06/03/12 07:52 PM
06/03/12 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
WELL.... you better tell us
Re: Chassis Flex [Re: MR_P_BODY] #1244211
06/03/12 09:23 PM
06/03/12 09:23 PM
N.E. Ohio
N.E. Ohio
Looks like its rotating the ladder bar crossmember like a torsion-bar.
Re: Chassis Flex [Re: 6bblFLASH] #1244212
06/03/12 10:11 PM
06/03/12 10:11 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
I'd check the ladderbar crossmember. You could be twisting it like a torsion bar
Mine rubs the tires some if I turn off the track to fast.
Re: Chassis Flex [Re: FastmOp] #1244213
06/03/12 11:17 PM
06/03/12 11:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
With the posts going around on cross member bracing, this is my thought. On the initial hit, the front mount is driven upward. With a plate on top of the front mount I added my roll cage diagonal directly on top of the mount. I can;'t see that it could rotate attached this way. What do you think?
Doug
Re: Chassis Flex [Re: dvw] #1244214
06/03/12 11:28 PM
06/03/12 11:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It actually pushes upwards at about a 45* angle...
forward and upwards
Re: Chassis Flex [Re: MR_P_BODY] #1244215
06/04/12 06:27 AM
06/04/12 06:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
forward and upwards
From what I've been taught, the vector changes. It starts upward at the hit when the vehicle is stationary. Then as the car moves it changes forward. I probably should have added the supports anyway. Never to late.
Doug
Re: Chassis Flex [Re: dvw] #1244216
06/04/12 08:09 AM
06/04/12 08:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
forward and upwards
Doug
Its dependent on the angle of the bar but when I
went to a chassis seminar it was in the 45* area..
you can calculate it based on the angle
