Dead Optima battery #1244057
06/02/12 01:21 PM
06/02/12 01:21 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
I have a red top Optima that I can't get to charge. My regular battery charger will try to charge it, but as soon as I remove it, I read 4.5 volts at the terminals. I also tried a battery tender specifically for AGM batteries, and it won't get it over 5 volts. Is there a way to revive them, or is it junk?
Dennis
Re: Dead Optima battery [Re: cudaboy] #1244058
06/02/12 01:38 PM
06/02/12 01:38 PM
Kirkland, Washington
Pacnorthcuda Offline
The next thing to try is to grab another battery and hook it up in parallel. You can also use something like a 12volt light bulb (you need a LOAD to put on the charger so it will provide output).
THe internal resistance of the Optima is too high, in its current (NPI) state of charge.
Make sense?
Re: Dead Optima battery [Re: Pacnorthcuda] #1244059
06/02/12 01:45 PM
06/02/12 01:45 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
My 2 Optimas are 8 yrs old or older, are used in cars I move once every year or 2. They are normally completly dead and a night on the trickle charger brings them up. I just brought both of them back to life 2 weeks ago, using one of them in my camper because the less than a yr old deep cycle lead/acid will not charge at all. I have never had one not charge yet.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Dead Optima battery [Re: Pacnorthcuda] #1244060
06/02/12 02:52 PM
06/02/12 02:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Make sense?
Correct, I was told that the gel-type Optima batteries have to be charged through another battery.
Re: Dead Optima battery [Re: cudaboy] #1244061
06/02/12 02:54 PM
06/02/12 02:54 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Dennis
I bought at a yard sale a 2-year-old red top Optima (clean, still had the "4/10" date stickers on it) for $30 that was supposed to have been removed from the car last week. I think they neglected to tell me the car had been sitting for a year before that... got it home and it had 0.1 volt Figured it was toast and I had a $7 core
I hooked it to an old-fashioned 8-amp charger (none of that float, auto shutoff, etc.) and at first it would not take any current. After about 20 minutes it began to draw a couple of amps and I left it on for several hours and it gradually climbed to 5 amps. Shut it off overnight and went to bed.
Next morning had 11 volts, 9.5 on my 100-amp load tester... better. Then I looked on the manufacturer's website and it says it's ok to blast it with a high charge rate to break up the sulfation, as long as the battery temp did not exceed 125F. So I hit it with 40 amps from the wheel-type charger for an hour until it was warm, discharged it all day through a one-ohm power resistor, then fast-charged again until it reached 15 volts (while charging), and backed off to about 20 amps until it was charging at 14.5 volts. (I could have gone to 15.5 volts, no current limit, without hurting it, again as long as it stayed under 125F).
(The reason for not fast-charging it at first, before cycling once, is that I could not be sure all six cells were equalized, and if one were much weaker it could result in overcharging the others...)
Now it's just in the green on the load-tester meter and has over 12 volts just sitting there Probably not as good as if it hadn't been allowed to sit totally flat, since it's impossible to break up all the sulfate, but for $30 instead of $189...
-Charles
ps as someone else (and the mfr.) pointed out, if your automatic charger won't kick in because it's too low, put another battery in parallel to get it going.
Re: Dead Optima battery [Re: DrCharles] #1244062
06/02/12 04:42 PM
06/02/12 04:42 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
I read about the parallel thing, but I don't think I need to do that. My charger is putting out 13.5 volts, the battery is just not charging. From what I understand, the parallel way is if the charger won't come on at all because the voltage is too low.
Dennis
Re: Dead Optima battery [Re: cudaboy] #1244063
06/02/12 05:05 PM
06/02/12 05:05 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I've read that another technique is to apply a high DC voltage across the battery (50-100 volts) with a suitable current-limiting resistor, and then wait. The sulfation may break down under the higher voltage. Then use a normal charger.
Some batteries just aren't salvageable though.
How long did you leave the Optima hooked up to the charger? Mine took an hour or so before it started pulling current, I think...
Re: Dead Optima battery [Re: cudaboy] #1244064
06/02/12 05:06 PM
06/02/12 05:06 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Old mechanic told me that every time you discharge a battery to 0, you kill 10% of its ability to recharge. So a 600A battery will only be about 540, then 484, then 436..so on. If you can get a camcorder or laptop batery to completely discharge (you cant, it usually turns itself off before it gets that low for protection) you will permanently damage it. But those optima batteries are supposed to be very good, nice score.
Re: Dead Optima battery [Re: DrCharles] #1244065
06/02/12 05:09 PM
06/02/12 05:09 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
I had the battery tender hooked up for over a week, no change. The regular charger I had hooked up for a full day, the guage showed it was charging, but the battery voltage drops when I unhook the charger. I think it's dead.
Dennis
Re: Dead Optima battery [Re: cudaboy] #1244066
06/02/12 05:16 PM
06/02/12 05:16 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Unfortunately I think you're probably right... but how much current was it drawing while on the regular charger? and what was the terminal voltage while charging?
Re: Dead Optima battery [Re: DrCharles] #1244067
06/02/12 07:53 PM
06/02/12 07:53 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
13.5 volts. Don't know what the current was.
Dennis
Re: Dead Optima battery [Re: cudaboy] #1244068
06/02/12 08:03 PM
06/02/12 08:03 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Try it on a large fast-charger (at 15.5 volts) for an hour... if it still doesn't come back at all, scrap it. Those batteries are good, but expensive, so it's worth a little effort
Re: Dead Optima battery [Re: cudaboy] #1244069
06/02/12 08:11 PM
06/02/12 08:11 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Remember, voltage is only a difference in electrical charge, and is not an indication of electrical flow.
A reading of 13-15 volts does not mean you are actually feeding any amps into the battery
Now, this talk of permanently draining a battery killing it, does that only apply to lead/acid car batteries? I know lithium ions are new tech, but I thought the NiMH Batteries would develop a memory where short cycling it by not draining fully or not charging fully, would diminish its capability
**Photobucket sucks**
