Re: Dead Optima battery
[Re: Pacnorthcuda]
#1244059
06/02/12 01:45 PM
06/02/12 01:45 PM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
My 2 Optimas are 8 yrs old or older, are used in cars I move once every year or 2. They are normally completly dead and a night on the trickle charger brings them up. I just brought both of them back to life 2 weeks ago, using one of them in my camper because the less than a yr old deep cycle lead/acid will not charge at all. I have never had one not charge yet.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: Pacnorthcuda]
#1244060
06/02/12 02:52 PM
06/02/12 02:52 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The next thing to try is to grab another battery and hook it up in parallel. You can also use something like a 12volt light bulb (you need a LOAD to put on the charger so it will provide output). THe internal resistance of the Optima is too high, in its current (NPI) state of charge.
Make sense?
Correct, I was told that the gel-type Optima batteries have to be charged through another battery.
[Re: cudaboy]
#1244061
06/02/12 02:54 PM
06/02/12 02:54 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have a red top Optima that I can't get to charge. My regular battery charger will try to charge it, but as soon as I remove it, I read 4.5 volts at the terminals. I also tried a battery tender specifically for AGM batteries, and it won't get it over 5 volts. Is there a way to revive them, or is it junk?
Dennis
I bought at a yard sale a 2-year-old red top Optima (clean, still had the "4/10" date stickers on it) for $30 that was supposed to have been removed from the car last week. I think they neglected to tell me the car had been sitting for a year before that... got it home and it had 0.1 volt Figured it was toast and I had a $7 core
I hooked it to an old-fashioned 8-amp charger (none of that float, auto shutoff, etc.) and at first it would not take any current. After about 20 minutes it began to draw a couple of amps and I left it on for several hours and it gradually climbed to 5 amps. Shut it off overnight and went to bed.
Next morning had 11 volts, 9.5 on my 100-amp load tester... better. Then I looked on the manufacturer's website and it says it's ok to blast it with a high charge rate to break up the sulfation, as long as the battery temp did not exceed 125F. So I hit it with 40 amps from the wheel-type charger for an hour until it was warm, discharged it all day through a one-ohm power resistor, then fast-charged again until it reached 15 volts (while charging), and backed off to about 20 amps until it was charging at 14.5 volts. (I could have gone to 15.5 volts, no current limit, without hurting it, again as long as it stayed under 125F).
(The reason for not fast-charging it at first, before cycling once, is that I could not be sure all six cells were equalized, and if one were much weaker it could result in overcharging the others...)
Now it's just in the green on the load-tester meter and has over 12 volts just sitting there Probably not as good as if it hadn't been allowed to sit totally flat, since it's impossible to break up all the sulfate, but for $30 instead of $189...
-Charles ps as someone else (and the mfr.) pointed out, if your automatic charger won't kick in because it's too low, put another battery in parallel to get it going.
[Re: DrCharles]
#1244067
06/02/12 07:53 PM
06/02/12 07:53 PM
Posts: 3,051 Bowling Green, KY
cudaboy
Bowling Green, KY
Unfortunately I think you're probably right... but how much current was it drawing while on the regular charger? and what was the terminal voltage while charging?
13.5 volts. Don't know what the current was.
Dennis
[Re: cudaboy]
#1244069
06/02/12 08:11 PM
06/02/12 08:11 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Remember, voltage is only a difference in electrical charge, and is not an indication of electrical flow.
A reading of 13-15 volts does not mean you are actually feeding any amps into the battery
Now, this talk of permanently draining a battery killing it, does that only apply to lead/acid car batteries? I know lithium ions are new tech, but I thought the NiMH Batteries would develop a memory where short cycling it by not draining fully or not charging fully, would diminish its capability
**Photobucket sucks**
