single field vs dual field alt... #1243837
06/01/12 10:36 PM
06/01/12 10:36 PM
lewiston, ID
cornucopia Offline OP
lewiston, ID
can I use a dual field alt on a pre-70 mechanical regulator system? I don't want to change the harness over to the electronic. I seem to recall reading about just grounding one of the field terminals and all will be well... maybe I am hallucinating...
Re: single field vs dual field alt... [Re: cornucopia] #1243838
06/01/12 10:38 PM
06/01/12 10:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You are correct....
Though actually what is commonly referred to as a dual field alternator is actually an isolated field alternator & only differs for the earlier design by not having one end of the field winding grounded....
Re: single field vs dual field alt... [Re: 1_WILD_RT] #1243839
06/01/12 10:54 PM
06/01/12 10:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You are correct....
That isn't technically true, the isolated field setup varies the resistance to ground to control the output, the early version switches the 12V to the field on and off to "chop" an output of whatever is needed. The isolated setup is still grounded, but thru the voltage regulator.
Don't be the exception.
Re: single field vs dual field alt... [Re: Supercuda] #1243840
06/01/12 10:58 PM
06/01/12 10:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You are correct....
Your talking about what the regulator does, not how the alternator is built...
Re: single field vs dual field alt... [Re: cornucopia] #1243841
06/01/12 11:26 PM
06/01/12 11:26 PM
yes ground the extra field terminal with a short piece of wire to the alt case & can probably remove the insulating washer to ground the brush/brush holder itself for a cleaner appearance
Re: single field vs dual field alt... [Re: RapidRobert] #1243842
06/02/12 12:05 AM
06/02/12 12:05 AM
Andrewh Offline
Andrewh  Offline
and it doesn't matter which one you ground or hook the field wire up to, just pick one.
Re: single field vs dual field alt... [Re: Andrewh] #1243843
06/02/12 01:59 AM
06/02/12 01:59 AM
lewiston, ID
lewiston, ID
cool! I have 14 dual field alts in the collection, and no singles... I will make it work.
