Carter AFB Comments PN 9636SA 0441 #1242357
05/30/12 07:43 PM
05/30/12 07:43 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
This carb came with a car I just bought. It looks like its never been on a car before Are they any good ? Ive always run stock pieces
Here are the specs.
http://www.carburetion.com/cartprice.asp
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242358
05/30/12 07:57 PM
05/30/12 07:57 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Pure junk. Not worth the postage it will take to send it to me. But go ahead, send it on.
JK I have always had better luck with the carters, tho most seem to lean towards the Holleys.
Parts are a little harder to come by to mod them, Holley stuff falls out of the trees, seems.
However, often times I find the Carters need less to make them work.
It takes gasoline to interest me.
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242359
05/30/12 07:57 PM
05/30/12 07:57 PM
reportedly they are good
Re: Carter AFB Comments PN 9636SA 0441 [Re: RapidRobert] #1242360
05/30/12 08:12 PM
05/30/12 08:12 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I put that same carb on my stock 440 in my 68 Charger in 1994, it is still there and is a great carb for me.
I had to adjust the idle one time on a trip to the Nats in Columbus, it got some dirt in it...It settled in after a couple of miles and got back to normal...
That was 10 yrs ago..
It has always seemed a little fat to me at WOT, but it simply works great..
Re: Carter AFB Comments PN 9636SA 0441 [Re: sthemi] #1242361
05/30/12 10:49 PM
05/30/12 10:49 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
It's about as close to a set it and forget it carb as you're going to find.Dave
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242362
05/30/12 10:53 PM
05/30/12 10:53 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Older' version-when Fed-Mogul was making 'em...
I've had one on top of a 440 for 20 years...
For ease of tuning, and reliability once you dial it in, I'll take it every time...
For a car that's driven more than 1320 at a time, I'll take 'em over a Holley ANY day of the week...
Re: Carter AFB Comments PN 9636SA 0441 [Re: VL21] #1242363
05/30/12 11:18 PM
05/30/12 11:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said but send it to me , I'm CLOSER
Re: Carter AFB Comments PN 9636SA 0441 [Re: JohnRR] #1242364
05/30/12 11:48 PM
05/30/12 11:48 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks for all the positive comments on this unit. Is the 0441 a date next to the part number? Does it mean 44 day of 1981?
1972 Corvette
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242365
05/30/12 11:49 PM
05/30/12 11:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes it's a date code , could be 91 , 2001 ???
Re: Carter AFB Comments PN 9636SA 0441 [Re: JohnRR] #1242366
05/31/12 12:03 AM
05/31/12 12:03 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
so When did they stop making these? everything now goes to the Edlebrock 1400 series right?
1972 Corvette
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242367
06/05/14 04:47 PM
06/05/14 04:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just picked up two of these carbs still shrink wrapped in their original boxes. Sounds like they are worth keeping?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Carter AFB Comments PN 9636SA 0441 [Re: 6PKRTSE] #1242368
06/05/14 06:19 PM
06/05/14 06:19 PM
dogdays Offline
dogdays  Offline
Why wouldn't they be? AFBs have been mixing air and fuel on engines for 50 years or more, and in some pretty high performance applications.
People used to say about the dual quad 409s that nothing compared to the roar when the two AFBs opened up.
I'm sure the same could be said about the carbs on 421s or 413s or 425s, etc.
I have a brand new 9410 that I bought for a Landcruiser project, it's waiting its turn.
Kudos to Edelbrock for keeping this seminal carb line going into the new century.
R.
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242369
06/06/14 04:12 AM
06/06/14 04:12 AM
Earth
Rob C Offline
Rob C  Offline
Earth
There an excellent carb. Take the time to dial that in mint and you'll love it.
The ONLY draw back to "AFB's" are the counter weighted air door for the secondary side. Roll into the secondary side rather than am the pedal. The pump shot doesn't always cover the secondary opening.
Re: Carter AFB Comments PN 9636SA 0441 [Re: 19cuda73] #1242370
06/06/14 10:47 AM
06/06/14 10:47 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
At one time both the Carter brand and Edelbrock brand carburetors were manufactured by Weber in Sanford, NC. Carter(Federal-Mogul) got out of the business at some point. I don't know if Weber still produces for Edelbrock.
