rad hose numbers to fit 3 row champion rad? #1242320
05/30/12 06:07 PM
05/30/12 06:07 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
my champion rad came with the top hose opposite the existing drivers and since the rad is shorter vertically i was wondering which hose to use on the bottom?
has any one had trouble lining up their tranny lines because of the diff. in the height of the hook ups?
this is an e-body big block
Re: rad hose numbers to fit 3 row champion rad? [Re: CUDA8U] #1242321
05/30/12 06:17 PM
05/30/12 06:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You didn't really expect a generic aftermarket replacement to drop right in place of a stock radiator ... or did you ???
Re: rad hose numbers to fit 3 row champion rad? [Re: JohnRR] #1242322
05/30/12 06:23 PM
05/30/12 06:23 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
no s*** i'm asking e-body owners if they have a number available for hoses to fit the application.
but thanks for your great comment....again
Re: rad hose numbers to fit 3 row champion rad? [Re: CUDA8U] #1242323
05/31/12 10:53 PM
05/31/12 10:53 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
This makes me laugh, sorry. Hope someone really helps/
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: rad hose numbers to fit 3 row champion rad? [Re: kilroy] #1242324
05/31/12 10:56 PM
05/31/12 10:56 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
another post going right now. Maybe what you need?
Re: rad hose numbers to fit 3 row champion rad? [Re: kilroy] #1242325
06/01/12 12:28 AM
06/01/12 12:28 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
my rad is different,the upper inlet is 8"s off the cap on the passenger side,the cap is centered 22" champion
thanks anyway
Re: rad hose numbers to fit 3 row champion rad? [Re: JohnRR] #1242326
06/01/12 03:24 AM
06/01/12 03:24 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Yes John, I do.
Re: rad hose numbers to fit 3 row champion rad? [Re: astjp2] #1242327
06/01/12 10:21 AM
06/01/12 10:21 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Yes John, I do.
Why not just use the flexible stainless stuff with the rubber couplers? That's what i'm using for the corvette radiator in my dakota also made by champion.
Re: rad hose numbers to fit 3 row champion rad? [Re: POS Dakota] #1242328
06/01/12 10:53 AM
06/01/12 10:53 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I had the same issue when I put a Champion in my car. I can't get you a part number now but Car Quest had the hose I needed.
