Brighter dash bulbs?
#12406
07/21/04 11:30 PM
07/21/04 11:30 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Just took my cluster out - any replacement bulbs brighter than the 158's it had in it? 194's look similar but I don't know if they're brighter or not. I don't want to have to go nuts special ordering some weird bulb, just curious if there are any differences.
Ride eternal, shiny and chrome
Re: Brighter dash bulbs?
[Re: DirectSubjection]
#12409
07/22/04 09:27 AM
07/22/04 09:27 AM
You also don't want to draw too much current and melt the wiring or pop the fuse. You also don't want hotter bulbs that may melt your cluster.
If you get all new correct bulbs and clean it real good, it'll be just fine, I'm sure.
$0.02
[Re: RobR]
#12415
07/22/04 02:23 PM
07/22/04 02:23 PM
Posts: 26,561 Santa Rosa, NOR*CAL.
Just Cameron
Dim lights are usually caused buy high resistance in the rheostat...
AKA the panel dimmer feature of the Headlight switch?
[Re: Just Cameron]
#12416
07/22/04 03:14 PM
07/22/04 03:14 PM
Posts: 1,864 Butler, PA
romanucci
Butler, PA
Yes.
