Brighter dash bulbs? #12406
07/21/04 11:30 PM
07/21/04 11:30 PM
Here
DirectSubjection Offline OP
Tacohead. The First and Only
Here
Just took my cluster out - any replacement bulbs brighter than the 158's it had in it? 194's look similar but I don't know if they're brighter or not. I don't want to have to go nuts special ordering some weird bulb, just curious if there are any differences.
Ride eternal, shiny and chrome
Re: Brighter dash bulbs? [Re: DirectSubjection] #12407
07/22/04 08:10 AM
07/22/04 08:10 AM
moparx Offline
moparx  Offline
for what it's worth : 158=.24watts, 194=.27watts,168=.35watts 192=.33watts so i think higher is brighter[?]. don't know if this helps or not. this info is from a G.E. lamp book. all #'s are 12v.
Re: Brighter dash bulbs? [Re: moparx] #12408
07/22/04 08:53 AM
07/22/04 08:53 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yep, my cluster was always too dimly lit for me except in deserted rural areas. I went up to the 192 from the 158 and noticed a big difference, was real happy with the results.
Re: Brighter dash bulbs? [Re: DirectSubjection] #12409
07/22/04 09:27 AM
07/22/04 09:27 AM
You also don't want to draw too much current and melt the wiring or pop the fuse. You also don't want hotter bulbs that may melt your cluster.
If you get all new correct bulbs and clean it real good, it'll be just fine, I'm sure.
$0.02
Re: Brighter dash bulbs? [Re: moparx] #12410
07/22/04 10:30 AM
07/22/04 10:30 AM
Here
Here
158=.24watts,
194=.27watts,
168=.35watts,
192=.33watts
Cool - thanks! I think I'll just go with 194's as I have enough of them lying around. That list should be in the tech area somewhere.
Re: Brighter dash bulbs? [Re: DirectSubjection] #12411
07/22/04 11:40 AM
07/22/04 11:40 AM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Maybe the problem lies elswhere in you electrical system where the bulbs aren't running at the proper voltage because of degraded/corroded connections etc.
Dan
Re: Brighter dash bulbs? [Re: dwbiggs] #12412
07/22/04 12:54 PM
07/22/04 12:54 PM
Here
Here
Dan
Honestly - I've never even turned the lights on in my Duster I just recall how my 69 Valiant was and wanted a little more light. Figured I'd replace the bulbs since I have the cluster out to change my dash pad.
Re: Brighter dash bulbs? [Re: DirectSubjection] #12413
07/22/04 01:30 PM
07/22/04 01:30 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline
The guy making the whiteface gauge overlays for the Duster Cluster offers LEDs that fit those sockets, and have 1 or 4 LEDs per bulb.
Re: Brighter dash bulbs? [Re: Just Cameron] #12414
07/22/04 01:46 PM
07/22/04 01:46 PM
Canada
RobR Offline
RobR  Offline
Canada
Dim lights are usually caused buy high resistance in the rheostat...
Re: Brighter dash bulbs? [Re: RobR] #12415
07/22/04 02:23 PM
07/22/04 02:23 PM
AKA the panel dimmer feature of the Headlight switch?
Re: Brighter dash bulbs? [Re: Just Cameron] #12416
07/22/04 03:14 PM
07/22/04 03:14 PM
Butler, PA
romanucci Offline
romanucci  Offline
Butler, PA
Yes.
Re: Brighter dash bulbs? [Re: romanucci] #12417
07/22/04 04:46 PM
07/22/04 04:46 PM
I never use that...Can I just get a On/Parking/Off with any old 3 way switch and simplify things back there a bunch?
