setting valve lash, solid roller cam, aluminum heads #1241265
05/28/12 06:06 PM
05/28/12 06:06 PM
NC
rickmoore69 Offline OP
NC
have a stroked 440 w/ stealth heads, xr280r roller cam, card says lash is 16 int/ 18 exh. I'm assuming that's hot. What should I set them cold. Engines been sitting a couple of years while I've recovered from lung cancer.
Thanks guys/gals
Re: setting valve lash, solid roller cam, aluminum heads [Re: rickmoore69] #1241266
05/28/12 06:28 PM
05/28/12 06:28 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
On my iron 440 block with aluminum heads (stage 6) I gained .004" from cold to hot. On my aluminum low block with aluminum heads I gain .015" from cold to hot. Hope this helps.
Re: setting valve lash, solid roller cam, aluminum heads [Re: rickmoore69] #1241267
05/28/12 06:45 PM
05/28/12 06:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thanks guys/gals
you need to make sure that is a hot lash or cold lash from the mfg. then go from there,,my comp calls for .020 hot exh/int and I set them .015 cold because my alum heads grow .005 at running temp.
