Re: setting valve lash, solid roller cam, aluminum heads
[Re: rickmoore69]
#1241267
05/28/12 06:45 PM
05/28/12 06:45 PM
dartman366
Mt. Vernon, Ohio
have a stroked 440 w/ stealth heads, xr280r roller cam, card says lash is 16 int/ 18 exh. I'm assuming that's hot. What should I set them cold. Engines been sitting a couple of years while I've recovered from lung cancer. Thanks guys/gals
you need to make sure that is a hot lash or cold lash from the mfg. then go from there,,my comp calls for .020 hot exh/int and I set them .015 cold because my alum heads grow .005 at running temp.
