valve lash for roller cam/aluminum heads #1241237
05/28/12 04:53 PM
05/28/12 04:53 PM
NC
rickmoore69 Offline OP
NC
what should the cold valve lash setting be for a solid roller cam w/ aluminum heads be? cam specs say 16 int/18 exh. Is that hot? what should cold be? May seem like a dumb question but I've let this thing set for a couple of years while getting my health back after a bout of lung cancer. Going to run a half marathon next weekend!
Re: valve lash for roller cam/aluminum heads [Re: rickmoore69] #1241238
05/29/12 06:34 AM
05/29/12 06:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The average cold setting for aluminum heads and an iron block would be .006" tighter cold. Start at .010" /.012" then check them hot.
Doug
Re: valve lash for roller cam/aluminum heads [Re: dvw] #1241239
05/29/12 02:16 PM
05/29/12 02:16 PM
Doug
Most valve settings on the cam cards are for hot setting, aluminum heads grow so start with -.006 from the hot setting. OP, congrats on whupping the big C I've had three different bouts with two types, early detection is the key to succes
