67 Barracuda with 33" tall slicks: which height fronts? #1241001
05/28/12 11:33 AM
05/28/12 11:33 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!I have a 67 barracuda which Im building into a race car.
I have 33" tall slicks out back with Cal Tracks suspension with stock height monoleafs.
I have to buy front drag skinnies and I was wondering which height should I get.
27"
28"
or
29"????
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241002
05/28/12 02:13 PM
05/28/12 02:13 PM
gregsdart Offline
gregsdart  Offline
What class or classes will the car run? If it is going to be a ten second car or faster, then a tall tire for foot brake to keep the car reaction slow enough. For super classes, very short. Bracket racing with a box, no difference.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241003
05/28/12 04:12 PM
05/28/12 04:12 PM
Franklin Furnace, OH
moparman1954 Offline
Depends on your headers. If they're fenderwells, 25 26 max. I have 25" 165r on my 68 cuda. 26" might fit. 28" won't fit, tried them.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: moparman1954] #1241004
05/28/12 06:44 PM
05/28/12 06:44 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Car has HEMI in it, no fenderwells, I still have the stock inner fenders, so it has to clear the stock inner fenders.
What class....we just do heads up racing down here in Peru. I would like to run in the 9s...maybe low 9s after some engine upgrades in the future...
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241005
05/28/12 09:22 PM
05/28/12 09:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241006
05/29/12 11:44 AM
05/29/12 11:44 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
any suggestions?
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241007
05/29/12 12:45 PM
05/29/12 12:45 PM
Out West
408strokerdart Offline
Out West
So, by heads up do you mean pro tree? or full tree? Full tree = what ever you like, pro tree = shortest possible (on most full body cars).
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: 408strokerdart] #1241008
05/29/12 07:22 PM
05/29/12 07:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
full tree.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241009
05/29/12 07:48 PM
05/29/12 07:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
not much room for a big tire up front
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: sixpackgut] #1241010
05/29/12 08:11 PM
05/29/12 08:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
how much room then?
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241011
05/29/12 08:14 PM
05/29/12 08:14 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Without altering (cutting it off) the front of the opening lip the most you'll fit and be able to turn properly will be a 26 inch tire.
Moroso 7.10 tires will fit but don't try to turn.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241012
05/29/12 09:16 PM
05/29/12 09:16 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
full tree.
No man We race pro tree, all at once
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: cbarracuda] #1241013
05/29/12 09:39 PM
05/29/12 09:39 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
full tree.
Still, we get lights flashing between the stage and launch light.
Isnt pro tree supposed to be only the launch light right after the stage light?
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241014
05/29/12 09:45 PM
05/29/12 09:45 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
why shortest possible if its a pro tree??? You get better vehicle reaction times with a shorter tire?
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241015
05/29/12 09:51 PM
05/29/12 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
full tree.
Full tree (Sportsman tree) you get the lights coming down...
pro tree is the pre stage, stage then the green...
either a .400 or .500 pro tree
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: MR_P_BODY] #1241016
05/29/12 09:58 PM
05/29/12 09:58 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
full tree.
We dont get the lights coming down in .5 intervals....
but after the stage light we do get the amber lights flashing real fast before the green light. I guess its a pro tree then?
I tought a pro tree was then the green light went on after the stage light with no amber lights in between.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241017
05/29/12 11:06 PM
05/29/12 11:06 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
we used a 500 pro tree, all three yellows at once
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: cbarracuda] #1241018
05/30/12 12:12 AM
05/30/12 12:12 AM
Out West
Out West
On a .500 pro tree you should still be good with a 26" tire. If it were .400 pro tree then you would want as small as practical.
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: 408strokerdart] #1241019
05/30/12 11:59 AM
05/30/12 11:59 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
why does everybody say that its ok 26" or smaller with a pro tree???
Why a bigger tire would not be adviseable?
Re: 67 Barracuda with 33" tall slicks: which height fronts? [Re: domingo] #1241020
05/31/12 12:50 PM
05/31/12 12:50 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
re
