'65 Chrysler Newport...disc brake swap? #1240083
05/26/12 03:48 PM
05/26/12 03:48 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Anyone know what I need to swap disc brakes on my '65 Newport??
Re: '65 Chrysler Newport...disc brake swap? [Re: DusterKrazy] #1240084
05/26/12 07:18 PM
05/26/12 07:18 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Disc spindles from a '69 to '73 C body will bolt on. The '73 setup is preferred because the rotor is cheaper but the 69 to 72 setup is fine.
Scarebird also makes a kit that uses a Dodge Ram caliper with a 70's Ford LTD rotor.
Re: '65 Chrysler Newport...disc brake swap? [Re: DusterKrazy] #1240085
05/26/12 08:07 PM
05/26/12 08:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The ideal set-up is to find a 73 C-body be it a Polara, Monaco, Newport Fury etc and take the spindles and everything brake related and install on your 65. Spindles are a direct bolt in.
If your 65 is a power brake car you will need to change to a disc brake booster as the drum booster doesn't have enough oomph to run discs properly.
The 73 booster can interfere with the column shift linkage on a 66 and newer. Not sure about the clearance with a cable shift like yours but it will physically bolt up. Console shift is a non issue.
The dual diaphragm from a 66-68 with Budd discs won't interfere with the linkage but is harder to find. I have one from a 69 300 on mine which IIRC is smaller diameter than the 73 but I don't know about clearance as mine is a console car.
Use the 73 master and proportioning valve and plumb it the same as the 73. 73 flex hoses should work but you might have to change how the hardline connects to the flex ie the angle it comes off the frame to orient the flex line properly to the caliper.
A couple of links. http://www.cbodydrydock.com/content.php?article.22
http://www.moparmusclemagazine.com/techa...on/viewall.html
Kevin
Re: '65 Chrysler Newport...disc brake swap? [Re: Twostick] #1240086
05/27/12 11:00 AM
05/27/12 11:00 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I used the 73 set up on my 65. My car is non power but I can't remember what master I used. I think it was the 73 non power disc unit. No issues with the cable shift.
Re: '65 Chrysler Newport...disc brake swap? [Re: belv2vert66] #1240087
05/29/12 09:26 PM
05/29/12 09:26 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
The '65 is column shifted and I guess I'd need to swap the factory style booster for a disc one.
Re: '65 Chrysler Newport...disc brake swap? [Re: DusterKrazy] #1240088
05/30/12 12:25 PM
05/30/12 12:25 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
The latest Mopar Muscle Magazine has an article on just this type of swap. When I had my 66 Chrysler 300, I went with the SSBC kit and a dual diaphragm booster. Worked as advertised....
