Low Nose A-Bodies #1240035
05/26/12 01:11 PM
05/26/12 01:11 PM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
I noticed in a lot of the pics of the old nostalgia Dusters they sit REAL low in the front. How is that done ?? Are they strut cars so they can be set down or can that be done to a torsion bar suspension ?? Love the old school look was thinking about seting my duster down in the nose.
Chris
Re: Low Nose A-Bodies [Re: hemiparts] #1240036
05/26/12 02:11 PM
05/26/12 02:11 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I don't know about the suspension, but it looked to me as if they lowered or angled the front fender down in the front.
Re: Low Nose A-Bodies [Re: hemiparts] #1240037
05/26/12 02:12 PM
05/26/12 02:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The older Pro Stock cas had relocated A-arms and that sort of thing.The easiest thing to do now is use drop spindles.I am going to lower my Demon down,and drop spindles is what I'll use.
Nautilus Racing-
Re: Low Nose A-Bodies [Re: Chris2581] #1240038
05/26/12 02:14 PM
05/26/12 02:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The MagnumForce unit on my E-body slammed the nose right down...I like the way it sits...
Re: Low Nose A-Bodies [Re: Dragula] #1240039
05/26/12 02:22 PM
05/26/12 02:22 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
without pictures it never happened
id love to see some of the "slammed" cars
Re: Low Nose A-Bodies [Re: 8urvette] #1240040
05/26/12 04:33 PM
05/26/12 04:33 PM
Raleigh N.C
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
heres some pics courtesy of prostockhemi.com ( thanks Fred ) ...
Re: Low Nose A-Bodies [Re: hemiparts] #1240041
05/27/12 04:38 AM
05/27/12 04:38 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: Low Nose A-Bodies [Re: hemiparts] #1240042
05/30/12 02:22 PM
05/30/12 02:22 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im pretty sure I read that Dick Landy and Sox and Martin got in a little trouble for "tapering" the front fender down a touch. I saw a picture of a fender off of a carlton car too that looked to be tapers to the nose.
Im sure If Reed piped in here we would know for sure.
Re: Low Nose A-Bodies [Re: Moparnut426] #1240043
05/30/12 03:17 PM
05/30/12 03:17 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
The "drooped" front ends were standard practice for years in Pro Stock and Comp Elim categories, as well as others. My Lebaron is "drooped" about 2 1/2" in front.
Re: Low Nose A-Bodies [Re: Moparnut426] #1240044
05/30/12 04:21 PM
05/30/12 04:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think they were actually lowering the bodies over the frame rails in front or basically "channelling" the front half of the cars.
Mopar to the bone!!!
Re: Low Nose A-Bodies [Re: hemiparts] #1240045
05/30/12 05:21 PM
05/30/12 05:21 PM
Chris
Do you have a early A body? If so try removing the lower control arm bump stop and lower the torsion bars until the it gets as low as you want it BTW, DO NOT let the lower control arm rest on the bump stop on the front sub frame with you or anyone else sitting in thecar
Re: Low Nose A-Bodies [Re: Cab_Burge] #1240046
05/30/12 09:17 PM
05/30/12 09:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I actually didn't like the MF setup but it was low... So low and with the added benefit of a wider stance you couldn't turn the wheel all the way with out the tire catching the finder lip and pealing it out DAMHIK
It wasn't in my car for more than 2 months before I decided I needed a chassis or my alum oil pan was going to become a skid plate
Motor is up and back and the tires moved in where they belong so there are no more issues with fender or oil pan clearance.
Re: Low Nose A-Bodies [Re: Bigcube] #1240047
05/30/12 10:19 PM
05/30/12 10:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my front clip is a homemade kevlar/carbon fiber which has the fenderline raked downwards, add to this 2" drop spindles & a homemade alloy oil pan with wings to keep it short so i don't do the Hansel n Grettel trick of leaving a return home trail to follow. on top of this i've hashed a Ford splitter/air damn/spoiler whatever to fit which makes loading onto a trailer a wee bit tricky but we have a handle on it now. i wouldn't want my junk lower than what it is now.
