What Are We Using For Break-In Oil These Days?
#1239191
05/24/12 10:29 PM
05/24/12 10:29 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
I was going to use Rotella on my fresh build (PONTIAC! ) Any other suggestions? Purple Power?
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: What Are We Using For Break-In Oil These Days?
[Re: JoesMopar]
#1239193
05/24/12 10:42 PM
05/24/12 10:42 PM
RangerDan440
yeah thats what I was planning on doing
[Re: DARTH V8Я]
#1239195
05/25/12 08:34 AM
05/25/12 08:34 AM
Posts: 4,880 Virginia
BSharp
Virginia
IF yours is a Pontiac 400 then straight 50 weight
Ow.
[Re: BSharp]
#1239196
05/25/12 08:59 AM
05/25/12 08:59 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
by "purple power" I'll assume you meant "royal purple"? I have some killer degreaser/floor cleaner soap thats called purple power. I don't think that would make a very good break in oil, but it will wash away all your assembly lube in short order! I wouldn't use the purple stuff, I believe it's all synthetic oil, and was not aware that the purple stuff came in a conventional oil? I did run the purple synthetic in my flat tappet big block after break in on the engine dyno and 1000 street miles, never had a problem.
**Photobucket sucks**
[Re: DARTH V8Я]
#1239198
05/25/12 09:39 AM
05/25/12 09:39 AM
Posts: 480 Texas
racer_amx
Texas
New cam break-in I just use cheap wallmart oil & a bottle of whatever favorite additive. Then for under load driving on a new engine I'll drain the old cheap stuff and use Amsoil. Tight clearances 5w30, loose 15w-40. IF yours is a Pontiac 400 then straight 50 weight
+1 for wally world oil
[Re: SILVER67]
#1239205
05/25/12 01:57 PM
05/25/12 01:57 PM
Posts: 5,268 NY
70440+6bbl
NY
Last two break-ins over the past year, I have used the Brad Penn 30wt oil made for this purpose, no need to add anything else to it.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: RangerDan440]
#1239207
05/26/12 10:49 AM
05/26/12 10:49 AM
RangerDan440
Brad Penn it will be
I need to fill it today so I can bar it over to attach the torque converter and trans and I will finish putting the carb, pulleys, etc back on, then Monday I can send it out for the exhaust and next weekend is the startup
