Anyone use the MADD headlight relay upgrade? Like it? #1238505
05/23/12 10:47 PM
05/23/12 10:47 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Can you please provide some feedback on the results and instalation of this kit. Thanks
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: frank] #1238506
05/23/12 11:33 PM
05/23/12 11:33 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I did it on my 67 BCuda, works great.
-Daty
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: frank] #1238507
05/24/12 02:31 AM
05/24/12 02:31 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I wired up some headlight relays I got from Summit based on the MAD upgrade. I never did any voltage testing to see what I had at the headlights before and after, but the headlights are definitely brighter now than they were before. Easy upgrade and it makes sense - full power is now getting to the headlights from the alternator, and you're greatly reducing the current that is normally running through the headlight switch.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: Evil Monkey] #1238508
05/24/12 03:43 AM
05/24/12 03:43 AM
hooziewhatsit Offline
I made my own harness using 12awg wire. I was losing 1-1.5 volts before the headlights Now I'm losing maybe 0.1v
But yea, noticeably brighter now.
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: frank] #1238509
05/24/12 02:21 PM
05/24/12 02:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I installed headlight relays on my D250 using this as a guide:
http://www.dieseltruckresource.com/dev/showthread.php?t=176263
It made an awesome difference and no wires were cut in the process.
I'll do the same thing to the Imperial this weekend.
- Stu Harmon
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: feets] #1238510
05/24/12 02:42 PM
05/24/12 02:42 PM
I guess I should also note, I found that the replacement bulkhead connector contacts fit in the new headlight plugs, as well as the relay harnesses I used. ie, fewer splices, and heavy gauge wire direct to the relays/headlights
Napa #725147
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: frank] #1238511
05/24/12 03:11 PM
05/24/12 03:11 PM
NE
bigtail Offline
bigtail  Offline
NE
I didn't buy a kit, just made my own harness and used some good relays. On my 87 Suburban, a few years ago. The low beams are as bright as my high beams used to be, and on high beams I can actually see deer lurking around, waiting to jump out in front of me before they do. Well worth the time and money. The crappy factory wiring must have been 22 gauge. I went with 12 gauge straight from the battery. HUGE improvement.
This page is made up completely of recycled electrons.
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: bigtail] #1238512
05/24/12 07:24 PM
05/24/12 07:24 PM
BDW Online content
BDW  Online Content
Do the running lights while you're at it.
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: BDW] #1238513
06/07/12 09:48 AM
06/07/12 09:48 AM
K
Kiddart Offline
Kiddart  Offline
K
I tried asking this last week on this but it didnt post. what do you do for the Running light circuit and brake lights turn signals etc.? Do you do the same for that position on the light switch as well as the low beams?? can it be done or did you not worry about that?? if you can share any more advise and lessons learned that would be great.
Thanks Kiddart
Thank you
Kiddart
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: Kiddart] #1238514
06/07/12 07:48 PM
06/07/12 07:48 PM
Texas
Daty Rogers Offline
Daty Rogers  Offline
Texas
I'm wondering why on the other lights. Low amperage, low load. Doesn't make sense. The MADD kit does the headlights only.
=Daty
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: Daty Rogers] #1238515
06/08/12 02:10 AM
06/08/12 02:10 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
=Daty
I agree. Besides, where's the relay going to be? Up front only on the fronts? No point. The headlights serve as your safety/other-driver-alertness lights up front.
Another relay for the rears? Under the dash to clutter that up? Or how about one under the dash to run both ends. Then you've got to got to get the good power to the relay. Through the bulkhead connector? What's the point?
BTW, my headlights are on relays. I didn't use Mad's kit, but another vehicle junction box for the relays - same difference. Major improvement.
Gotta get it done someday on my daily driver.
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: MoparMarq] #1238516
06/08/12 01:13 PM
06/08/12 01:13 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I've done home-brewed and Summit kits on 6-7 cars over the years, and yep, it's worth it!
Re: Anyone use the MADD headlight relay upgrade? Like it? [Re: Fury Fan] #1238517
06/11/12 03:27 PM
06/11/12 03:27 PM
Minneapolis, MN
moparguy Offline
moparguy  Offline
Minneapolis, MN
Just found this thread. That link you posted feets makes a real nice setup and I like not having to cut wires. I'll be doing that this week on the new yorker. Thanks!
