Re: Anyone use the MADD headlight relay upgrade? Like it?
[Re: frank]
#1238507
05/24/12 02:31 AM
05/24/12 02:31 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I wired up some headlight relays I got from Summit based on the MAD upgrade. I never did any voltage testing to see what I had at the headlights before and after, but the headlights are definitely brighter now than they were before. Easy upgrade and it makes sense - full power is now getting to the headlights from the alternator, and you're greatly reducing the current that is normally running through the headlight switch.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Evil Monkey]
#1238508
05/24/12 03:43 AM
05/24/12 03:43 AM
Posts: 3,884 Oregon
hooziewhatsit
I made my own harness using 12awg wire. I was losing 1-1.5 volts before the headlights Now I'm losing maybe 0.1v But yea, noticeably brighter now.
[Re: frank]
#1238509
05/24/12 02:21 PM
05/24/12 02:21 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I installed headlight relays on my D250 using this as a guide: http://www.dieseltruckresource.com/dev/showthread.php?t=176263It made an awesome difference and no wires were cut in the process. I'll do the same thing to the Imperial this weekend.
[Re: frank]
#1238511
05/24/12 03:11 PM
05/24/12 03:11 PM
Posts: 489 NE
bigtail
NE
I didn't buy a kit, just made my own harness and used some good relays. On my 87 Suburban, a few years ago. The low beams are as bright as my high beams used to be, and on high beams I can actually see deer lurking around, waiting to jump out in front of me before they do. Well worth the time and money. The crappy factory wiring must have been 22 gauge. I went with 12 gauge straight from the battery. HUGE improvement.
This page is made up completely of recycled electrons.
[Re: BDW]
#1238513
06/07/12 09:48 AM
06/07/12 09:48 AM
Posts: 1,550 Michigan
Kiddart
I tried asking this last week on this but it didnt post. what do you do for the Running light circuit and brake lights turn signals etc.? Do you do the same for that position on the light switch as well as the low beams?? can it be done or did you not worry about that?? if you can share any more advise and lessons learned that would be great. Thanks Kiddart
Thank you Kiddart
[Re: Daty Rogers]
#1238515
06/08/12 02:10 AM
06/08/12 02:10 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I'm wondering why on the other lights. Low amperage, low load. Doesn't make sense. =Daty
I agree. Besides, where's the relay going to be? Up front only on the fronts? No point. The headlights serve as your safety/other-driver-alertness lights up front.
Another relay for the rears? Under the dash to clutter that up? Or how about one under the dash to run both ends. Then you've got to got to get the good power to the relay. Through the bulkhead connector? What's the point?
BTW, my headlights are on relays. I didn't use Mad's kit, but another vehicle junction box for the relays - same difference. Major improvement.
Gotta get it done someday on my daily driver.
