dumb question about oil filter #1237703
05/22/12 12:43 PM
05/22/12 12:43 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I'm just changing my oil and filter and wondered what method you use to cut your filter for inspection. Tin snips ? grinding wheel ? hacksaw ?
Do you cut it screw thread down, to stop anything falling in or what ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: dumb question about oil filter [Re: deaks] #1237704
05/22/12 12:50 PM
05/22/12 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Filter cutter - designed for the job. A chain style pipe / tubing cutter will work also, but more of a hassle. Anything else and you will contaminate what you are trying to view.
Fastest 300
Re: dumb question about oil filter [Re: Crizila] #1237705
05/22/12 12:53 PM
05/22/12 12:53 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I haven't got one, so i'll try tin snips, thet wont contaminate it.
Mick
best 60ft 1.36
Re: dumb question about oil filter [Re: deaks] #1237706
05/22/12 02:36 PM
05/22/12 02:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mick
True Cut the paper element apart off of the steel center at both ends and then cut it length wise so you can spread it out and look at the bottom of the folds
Re: dumb question about oil filter [Re: Cab_Burge] #1237707
05/22/12 02:51 PM
05/22/12 02:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
PM me if you need a cutter.
Re: dumb question about oil filter [Re: topside] #1237708
05/22/12 03:41 PM
05/22/12 03:41 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Cab
Thanks for the advice.
Topside
It's nice of you but i'm not exactly round the corner.
Note the robin hood reference LOL
Mick
best 60ft 1.36
Re: dumb question about oil filter [Re: deaks] #1237709
05/22/12 04:06 PM
05/22/12 04:06 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
in case you slip - have a first aid kit handy - the filter cans are sharp!!
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: dumb question about oil filter [Re: MRMOPAR] #1237710
05/22/12 04:58 PM
05/22/12 04:58 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Last time I had a issue I just spun the filter off and sure enough you could see the shavings and I poured the filter out and also very sparkly.
67' charger 499 RB 10.57 at 127
