Trunk battery cable - inside or under the car? #1236638
05/20/12 09:36 PM
05/20/12 09:36 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
I've relocated the battery to the trunk in my 451 Dart. I have the appropriate heavy cable. Should I run it under the car, where it could be damaged by rocks or other debris, or through the passenger compartment where it's protected but could be more of a fire hazard in the event of a short... thoughts?
thanks
-Charles
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236639
05/20/12 11:04 PM
05/20/12 11:04 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I would run it inside the car. Just be sure to use a good fuse back at the battery and you wont have a fire hazard.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236640
05/20/12 11:28 PM
05/20/12 11:28 PM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
thanks
-Charles
I had a fire in Sinnamon back around 1980 when a couple big friends sat in the back leaving some club one night.
Back seat shorted the + cable. Had to kick out the back seat bottom and put the carpet fire out. Not fun.
I leave batteries up front anymore. Less drama.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Trunk battery cable - inside or under the car? [Re: BrianShaughnessy] #1236641
05/20/12 11:31 PM
05/20/12 11:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Run a ford solenoid in the rear so the fat wire isn't hot all the time. From your battery cut off switch, run a 6-8 gauge wire up to your power distribution point. Easier to fuse the 6-8 gauge as well.
I don't like having that fat 1 gauge or so wire hot all the time.
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236642
05/20/12 11:53 PM
05/20/12 11:53 PM
West Plains, MO
West Plains, MO
Thanks for the solenoid suggestion! Think I'll do it that way
I should point out that the common Ford part, intended for starter use, has an intermittent-duty coil and will overheat (and probably fail) if used continuously. There is an identical looking part that has a continuous-duty coil and that would be the one to buy...
I don't have the p/n handy at the moment, but I bought one for my '87 International big-truck years ago after discovering it had been "rigged" for yard-dog use with the intermittent one
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236643
05/21/12 12:05 AM
05/21/12 12:05 AM
RobX4406 Offline
RobX4406  Offline
S-605 continuous duty relay.
Here's a schematic using a ford solenoid and S605 in the alt line. I trigger the S605 from a keyed sources on street driven stuff so it doesn't draw when the master cutoff is on.
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236644
05/21/12 01:24 PM
05/21/12 01:24 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I did it the same way except I added a fuse between the solenoid and the alternator wire.
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236645
05/21/12 01:47 PM
05/21/12 01:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I think a properly fused cable will always be safer than an unfused cable that's triggered by a relay/solonoid.
Modern large amperage fusing solutions are compact, easy to install and very reliable, they protect the cable 100% of the time and you don't have to run a redundant second wire for power/charging.
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236646
05/21/12 02:00 PM
05/21/12 02:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is basically what I did as my battery cable to the starter goes under my carpet and is only hot while cranking as I use a Ford style starter solenoid. Then I took a 60 amp type of fuse link with eyelet terminals on it and bolted it right to the battery and ran 8 gauge wire from it to the hot terminal on the factory starter relay to feed everything in the car. That way the hot feed wire is fused with the 60 amp fuse. Ron
Re: Trunk battery cable - inside or under the car? [Re: jbc426] #1236647
05/21/12 03:18 PM
05/21/12 03:18 PM
RobX4406 Offline
RobX4406  Offline
Safer is a loose term.
My reason for using a relay in both starter and alt lines is when you throw the master, EVERYTHING outside about a 2' cube around the battery is dead. No live alt wire to the front. If you've never seen a car burn because of a live alt wire, even with a fusable link, you just haven't lived...
I don't like running the starter amperage through the master cutoff.
Fuse a 1 gauge cable with a fuse large enough to handle starter load and it can and will smolder for a long time before that fuse pops, if that's what you are using it for. At what cost as well.
I'll take the 2-4 extra pounds that I might have over the other methods that I've seen, like the minimum std. Just personal preference.
Pick your preferred method and run with it.
Re: Trunk battery cable - inside or under the car? [Re: Todd] #1236648
05/21/12 03:35 PM
05/21/12 03:35 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
https://board.moparts.org/ubbthreads/upload2/7215086-DSC00788%28Large%29.JPG
Don't mean to hijack, but are those two terminals through the sheet metal by the license plate inset meant for a battery tender or power takeoff or something?
I'd like to do something similar to mine so I don't have to open the trunk to put on the battery tender in the off-season.
Re: Trunk battery cable - inside or under the car? [Re: MoparMarq] #1236649
05/21/12 03:48 PM
05/21/12 03:48 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Yes, its terminals for a battery charger.
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236650
05/21/12 09:41 PM
05/21/12 09:41 PM
West Plains, MO
West Plains, MO
I concur, and as overweight as I am, an extra couple lbs for another wire and relay is immaterial
An intermittent duty starter solenoid (for the starter line) is easily found. But I'm getting nowhere with Internet searches for "S605" or other continuous duty relay... the local chain stores probably won't help much since they are conditioned to parrot "year, make, model". Would they actually know what that part number is??
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236651
05/21/12 11:01 PM
05/21/12 11:01 PM
Ohio
Todd Offline
Todd  Offline
Ohio
The one I have is from Napa. These are the same ones used on electric golf carts if that helps.
Re: Trunk battery cable - inside or under the car? [Re: Todd] #1236652
05/21/12 11:16 PM
05/21/12 11:16 PM
RobX4406 Offline
RobX4406  Offline
The Napa site used to be good, type in a different manufacture number and it would kick out their item...
Found this site. May help.
http://www.ase-supply.com/Solenoids_s/44.htm
200 amp cole hersee for mif $30 range. 85 amp one in there too.
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236653
05/22/12 12:04 AM
05/22/12 12:04 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
I have a 70 Dart and I was able to squeeze the battery cable into the wire trough that runs along side the seat and under the sill plate. It then goes behind the kick panel and comes out under the dash. Since I have an automatic I put a bulkhead terminal in the hole for the clutch push rod and then ran the same diameter wire on the other side down to the starter. Then a wire from the starter up to the solenoid.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Trunk battery cable - inside or under the car? [Re: MadMatt] #1236654
05/22/12 01:28 AM
05/22/12 01:28 AM
West Plains, MO
West Plains, MO
Thanks for the link, RobX... they're on the way from ASE Supply, one intermittent and one continuous-duty
I am also planning to run the heavy starter cable (hot only on start) in the left hand wiring trough. Probably will use a #4 for the alternator to minimize drop (since it's a CS-130) back to the trunk, but it'll be shorter to run it on the right since the battery and alt are both on that side.
Then I need to run one more feed back to the dash and underhood area to power everything... HHR fan, MSD, headlights, instruments, heater fan, accessories... if it weren't for the need of a master cutoff switch I could just power everything off the alternator hot stud without all the extra copper...
Bulkhead terminals are neat but they add two more points to corrode or come loose... thinking of holesaw + grommets instead
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236655
05/22/12 02:08 AM
05/22/12 02:08 AM
RobX4406 Offline
RobX4406  Offline
Happy to help. There are lots of ways to do this,
You could also break the alt line back to the battery, put in a power distribution stud/panel and run the lights/fan power from there with relays being triggered from switches on the down stream side of your master switch.
Re: Trunk battery cable - inside or under the car? [Re: RobX4406] #1236656
05/22/12 11:46 AM
05/22/12 11:46 AM
K
kielbasa Offline
kielbasa  Offline
K
about running a jumper wire on the starter (instead of switched +12V to just the small terminal on starter), are you guys experiencing starter run-on and/or starter crank without the pinion engaging by doing this?
I ran into this situation when doing the same on a permanent magnet starter on v-twin lawn garden engine. I think the starter begins to act as a generator and keeps itself energized for a few seconds after engine starts.
Re: Trunk battery cable - inside or under the car? [Re: DrCharles] #1236657
05/22/12 05:09 PM
05/22/12 05:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
3 cables from front to back? Are you going to fuse the second and third cables or are you going to use the solonoids to turn them off like your doing with starter cable?
Inexpensive modern fuses can easily handle loads as heavy as a cranking starter and still blow almost instantly before you smoulder a cable.
If you are burning up wires before your fuses blow, you're either using the wrong gear, or don't have your set-up wired right.
