Re: 73 340 throttel bracket and kick down linkage
[Re: gtx6970]
#1235589
05/19/12 11:53 AM
05/19/12 11:53 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
I haven't been able to find concrete evidence as to which bracket was used on the post 71 small blocks. So bear with me here as I am relying on the manufacturer. BUT, IMO it comes down to what style of kickdown linkages are being used.
I have the second bracket which I think may be correct but the rod from the bracket to the carb I have is wrong. The 2bbl return spring bracket I tweaked and it works fine for now at least.
I'll snap some pictures of what I have.
[Re: AdamR]
#1235591
05/19/12 12:34 PM
05/19/12 12:34 PM
AdamR
Bethel Ct
[Re: AdamR]
#1235592
05/19/12 05:39 PM
05/19/12 05:39 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I just switched from a 318 2 barrel to 340 thermoquad and the 318 linkage was the same. I will try to post a few pics tonight.
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
[Re: fireeng]
#1235593
05/19/12 08:12 PM
05/19/12 08:12 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
My 73 318 used the single bolt throttle return spring bracket. I thought the two bolt brackets were 74 only.
You must be working on an A-body with the two piece kickdown linkage. E-bodies used a single piece linkage.(E-body 340 linkage had a yellow paint mark on the carb end as seen in my picture above)
[Re: burdar]
#1235594
05/19/12 09:52 PM
05/19/12 09:52 PM
AdamR
Bethel Ct
[Re: AdamR]
#1235595
05/19/12 10:44 PM
05/19/12 10:44 PM
fireeng
near New Haven, CT
pics from an e body. carb is a 74 model using 71 318 linkage.
[Re: AdamR]
#1235599
05/20/12 06:20 PM
05/20/12 06:20 PM
fireeng
near New Haven, CT
Just to clarify, the throttle linkage from the 318 was the same. The kickdown linkage was different on my swap.
