727 with Manual Valve Body-TF-2 Compatability ? #1235563
05/18/12 10:09 PM
05/18/12 10:09 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Guys, Will I Have Any Issues Replaceing My Current Valve Body That Has Had A Transgo TF-2 Kit In It, With A Cheeta Manual Valve Body Because Of The Other Mods That Are In The Tranny Per The TF-2? Tom
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: Tom Fox] #1235564
05/18/12 10:11 PM
05/18/12 10:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used to run the Trans-go stuff and installed the Cheetah w/out any issues as most of the mods are in the vb itself.........
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: Tom Fox] #1235565
05/18/12 11:06 PM
05/18/12 11:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is the question can you put in a Cheetah Manual VB where a TF-2 was ?
Yes , but if there is a plug in the high gear clutch apply port I think you want to take it out .
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: JohnRR] #1235566
05/19/12 01:10 AM
05/19/12 01:10 AM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Yes, That Is What I Am Asking. So The Plug Would Need To Come Out, But The Other Mods Should Be O.K. ?
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: JohnRR] #1235567
05/19/12 01:56 AM
05/19/12 01:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe I got lucky or didn`t have that mod cos I`ve been driving/racing this way forever........ Thankxxxx for the info.
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: Thumperdart] #1235568
05/19/12 09:09 AM
05/19/12 09:09 AM
NC
440Jim Offline
440Jim  Offline
NC
The restrictor plug in the front clutch passage is for adjusting the timing of the 2-3 shift. That plug has a hole in it to slow down application of the front (3rd gear) clutch, to give time for the front band (2nd gear) to release. This can occur when increasing line pressure or using a 5.0 front band lever. In some applications, the 2-3 shift suffers from shift overlap with both parts engaged for a fraction of a second for a short lock up which can feel like a tire chirp or "hard" shift which is really the quick slow down then speed up of the tires.
You can enlarge the restrictor plug hole or remove it entirely to fine tune the 2-3 shift.
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: Tom Fox] #1235569
05/19/12 09:52 AM
05/19/12 09:52 AM
JohnRR Offline
JohnRR  Offline
Other than the restrictor, shimming the rear servo solid and replacing it's spring there really aren't any other mods done when installing a TF-2. The TF-2 is designed to be installed on your back in the driveway.
I don't know what mods have to be done to install the Cheetah though.
Re: 727 with Manual Valve Body-TF-2 Compatability ? [Re: JohnRR] #1235570
05/20/12 10:06 AM
05/20/12 10:06 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Do you have the instructions for both ? You may find that that they require a lot of the same modifications to the rear servo, front servo, and cupped orfice plug.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
