Re: 727 with Manual Valve Body-TF-2 Compatability ?
[Re: Tom Fox]
#1235565
05/18/12 11:06 PM
05/18/12 11:06 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Guys, Will I Have Any Issues Replaceing My Current Valve Body That Has Had A Transgo TF-2 Kit In It, With A Cheeta Manual Valve Body Because Of The Other Mods That Are In The Tranny Per The TF-2? Tom
Is the question can you put in a Cheetah Manual VB where a TF-2 was ?
Yes , but if there is a plug in the high gear clutch apply port I think you want to take it out .
[Re: JohnRR]
#1235566
05/19/12 01:10 AM
05/19/12 01:10 AM
Posts: 146 florida/ Georgia
Tom Fox
florida/ Georgia
Yes, That Is What I Am Asking. So The Plug Would Need To Come Out, But The Other Mods Should Be O.K. ?
[Re: Tom Fox]
#1235569
05/19/12 09:52 AM
05/19/12 09:52 AM
JohnRR
U.S.S.A.
Other than the restrictor, shimming the rear servo solid and replacing it's spring there really aren't any other mods done when installing a TF-2. The TF-2 is designed to be installed on your back in the driveway.
I don't know what mods have to be done to install the Cheetah though.
[Re: JohnRR]
#1235570
05/20/12 10:06 AM
05/20/12 10:06 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Do you have the instructions for both ? You may find that that they require a lot of the same modifications to the rear servo, front servo, and cupped orfice plug.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
