Moser or Strange?? #1235052
05/17/12 06:05 PM
05/17/12 06:05 PM
Finally a HUSKER again
Moparnut426 Offline OP
Strange will sell me a custom length 30 spline set of "race" axles with bearings and 3" studs for 470 bucks,
Moser will sell me a se of 30 spline custom alloy axles for 370 bucks no studs, or bearings,
Whos is better, any plus or minus remarks appreciated.
kasey
Re: Moser or Strange?? [Re: Moparnut426] #1235053
05/17/12 06:28 PM
05/17/12 06:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Moser for street strip , Strange for race only.
That being said , I ran 35 spline Strange axles on the street for a long time with no problems.
The difference is in the alloy and heat treat as I understand it.
Moser is a better choice for side loading and street type impact loading. More malleable or less brittle depending on how you look at it , but I don't know what kind of hammering you'd need to fracture a Strange axle. I have 30 spline Mosers in my deal now and I am perfectly happy with them.
Re: Moser or Strange?? [Re: tubtar] #1235054
05/17/12 06:32 PM
05/17/12 06:32 PM
Both are similar "race" application axles you just get a better deal buying the strange set up with bearings and studs.
Re: Moser or Strange?? [Re: Moparnut426] #1235055
05/17/12 06:36 PM
05/17/12 06:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Then Moser has changed their manufacturing or added another line.
Strange axles ( the race axles ) are through hardened.
Mosers have a case hardening , or did anyway.
Much like production axles , but with better steel.
And that made them the better choice for dual use..........that is my understanding of the way the land lays , but I bought my Mosers six years ago so things may have changed.
Re: Moser or Strange?? [Re: tubtar] #1235056
05/17/12 07:04 PM
05/17/12 07:04 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Did you contact Doc Diff, and see what his prices were? Either choice you make on the 2 you asked about will work good for your app. . I have ran both types on the street and hard on the track with a heavy e body. Doc also sent me a set 358 delivered, but I never used them on the street.
Re: Moser or Strange?? [Re: Mopar-Al] #1235057
05/17/12 07:16 PM
05/17/12 07:16 PM
Renton Washington
Triple Threat Offline
Renton Washington
Why 30 as opposed to 35?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Moser or Strange?? [Re: Triple Threat] #1235058
05/17/12 07:22 PM
05/17/12 07:22 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I wonder'ed that myself, but figured it was an easy install without having to pull it completely down. Enough for his combo
Re: Moser or Strange?? [Re: Mopar-Al] #1235059
05/17/12 07:28 PM
05/17/12 07:28 PM
Renton Washington
Renton Washington
Agreed, probably what the carrier is set up for already. If the unit needs rebuilt though now is the time to change to 35 before axles are purchased.
Re: Moser or Strange?? [Re: Triple Threat] #1235060
05/17/12 07:42 PM
05/17/12 07:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Probably 8-3/4
Re: Moser or Strange?? [Re: Defbob] #1235061
05/17/12 07:56 PM
05/17/12 07:56 PM
Renton Washington
Renton Washington
Nah, he's narrowing a Dana to fit his Demon. There has been like 3 threads about it this week
-Dustin
Re: Moser or Strange?? [Re: Triple Threat] #1235062
05/17/12 08:38 PM
05/17/12 08:38 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Call cass. He can get you a better deal and they will come with bearings and 3" x .500 studs. I believe they are around $300 plus shipping.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Moser or Strange?? [Re: tubtar] #1235063
05/17/12 08:39 PM
05/17/12 08:39 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Obviously, you're not aware of Strange's S/T axles. S/T stands for Street/Track. I ran them in my street/strip blown Hemi Duster, and they are holding up nicely.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Moser or Strange?? [Re: DusterDave] #1235064
05/17/12 09:52 PM
05/17/12 09:52 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Strange or moser either one will work. I like the machine work on the Strange stuff, but have used both. Mike Let me know if I can help!
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Moser or Strange?? [Re: mr2performance] #1235065
05/17/12 11:12 PM
05/17/12 11:12 PM
To be honest with you guys, I havent gottent he axle out yet, but its a Dana 60 hd out of a dodge van, and according to randys ring and pinion its got either 30 or 35 axles in it.
Its a 4:10 sure grip to.
But If its a 35 ill be stoked!!
Re: Moser or Strange?? [Re: DusterDave] #1235066
05/18/12 12:02 AM
05/18/12 12:02 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am aware of them......as I recall , they were pricier than Mosers when I bought mine and that was the deciding factor.
They are an option for sure.
Re: Moser or Strange?? [Re: tubtar] #1235067
05/18/12 01:39 AM
05/18/12 01:39 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
What is this rear going in ?
How much hp ?
I have Moser axles in my 8 3/4.
Came with green bearings and long studs.
Re: Moser or Strange?? [Re: Moparnut426] #1235068
05/18/12 08:33 AM
05/18/12 08:33 AM
an8sec70cuda Offline
Either one will work fine, both make high quality parts. I use Moser stuff just b/c they've always been good to me and easy to deal with. Not to mention I've worked on a few very fast cars w/ Moser filled rears.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moser or Strange?? [Re: demon440] #1235069
05/18/12 08:40 AM
05/18/12 08:40 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I just pulled my Moser 35 spline axles out of my 8 3/4 that I just broke (bent the housing)...the axles look as good as the day I put them in 10 years ago . I'm happy with Moser's stuff.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
