Help wiring a Engine Run stand please! (Easy diagram) #1234677
05/16/12 11:05 PM
05/16/12 11:05 PM
Vancouver, WA
Cuda Cody Offline OP
Vancouver, WA
Built a modular engine run stand to break in motors and was hoping to get some thoughts on wiring it. I want to run the alternator and a fuss buss. Could someone mark up the photo below to help me wire this thing? :1zhelp: I tried the search, but didn't find what I needed.
I will update the diagram so next time some does a search they can use it too if someone can help.
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234678
05/16/12 11:06 PM
05/16/12 11:06 PM
Vancouver, WA
Vancouver, WA
Here's the run stand. I made it modular so it can fit any engine and so I can take it apart to store it when not in use.
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234679
05/16/12 11:27 PM
05/16/12 11:27 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
It's Swifty! Swifty, you toad sucker!
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: zrxkawboy] #1234680
05/16/12 11:51 PM
05/16/12 11:51 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Like this...
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Bill MeLater] #1234681
05/17/12 12:47 AM
05/17/12 12:47 AM
Vancouver, WA
Vancouver, WA
WOW, that looks like fun! Someone knows what they are doing!
Thanks for the tech links. They helped, but I'm still not getting it.
Do I need an Ammeter?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234682
05/17/12 09:02 AM
05/17/12 09:02 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i your just using it for break in why are you going with a complete charging system?
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: bonefish] #1234683
05/17/12 10:51 AM
05/17/12 10:51 AM
Vancouver, WA
Vancouver, WA
Good idea. I was using the ALT fan belt to spin the water pump which I can still do, and I'm fine without using the charging system. That gets rid of the voltage regulator and ammeter.
Where to I get power for the coil?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234684
05/17/12 11:44 AM
05/17/12 11:44 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I think you have a couple things mis-labelled, and you do not have a ballast.
I'll do a rough remix of your picture and post.
Just as a suggestion, wiring diagrams tend to follow the rule of power on top, down through the components to ground at the bottom.
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: RodStRace] #1234685
05/17/12 12:02 PM
05/17/12 12:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
As said, I think the main feed for the starter switch is the center post, not the smaller side post.
I did not include the ballast and ignition wiring. The links in a past post cover that.
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: RodStRace] #1234686
05/17/12 01:05 PM
05/17/12 01:05 PM
Vancouver, WA
Vancouver, WA
This helps a lot. Thank you. The key switches are labeled on the back and I think the close up photo makes the center post look a lot bigger. I will check, but I think they are all the same size. And I'm pretty sure I have them labeled correct, but I'll double check to be sure.
Thanks for the tip on how to lay out the wiring diagram. I've fixed mine to look more like yours.
Does this diagram look closer to correct?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234687
05/17/12 06:43 PM
05/17/12 06:43 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep.
Note that you have no power feed to the ignition switch.
The fuse block is really not needed.
You could run circuit breakers instead.
Will you have mechanical gauges?
Wiring is simple if you take it slow, understand what is happening and follow basic rules.
1. You need a big cable from Battery - to ground. ALL power feeds back through this cable.
2. You need a big cable from the battery + to the starter. This supplies the most amps (flow) to the component that uses the most power.
3. The starter needs a trigger. This is the power feed from Batt+ to the ignition switch, thru the switch when the key is turned to the start position, which goes to the solenoid. The solenoid is supplied Batt + with a big wire. When it's triggered with the switch circuit, it connects this to the wire that goes to the smaller terminal in the starter.
The solenoid works like a relay. A small trigger opens a big valve.
Here's a good video of a ford style solenoid.
http://www.youtube.com/watch?v=pp8D99bIt3Y
The Chrysler style does not handle all the battery power to the starter like the Ford shown, just the trigger part.
It also has 2 heavy terminals and 2 lighter terminals.
The light terminals are the ignition switch input (+) and the clutch or neutral safety switch (-).
These cause the BATT and SOL terminals to be connected, allowing power to flow from the battery to the starter.
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: RodStRace] #1234688
05/17/12 07:41 PM
05/17/12 07:41 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
Awesome job on the stand !
Would you have more pics and dimensions ? Will a tranny bolt up with it also ?
I'm wanting to build one also..... And sorry I'm no help on the wiring either....
Donnie
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: DonnieLawson] #1234689
05/18/12 12:29 AM
05/18/12 12:29 AM
Vancouver, WA
Vancouver, WA
Thanks for the help guys. I wired it just like the last diagram and it worked perfectly. 2 gallons of gas lasted about as long as the battery and I got about 25 minutes of 2,000 rpm break in.
As for hooking a transmission up to the stand, I built mine 100% modular so I can make any adjustments. Everything slides and moves, but once locked in place it's rock solid. I used receiver hitch steel (about $10 a foot) and drilled / welded nuts in place. I will post some more photos.
Again, thank you for all the help with the wiring.
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Cuda Cody] #1234690
05/19/12 12:24 AM
05/19/12 12:24 AM
Arizona
jsully Offline
jsully  Offline
Arizona
Great job on this. I too would like some demensions and photos of the structure!
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: bonefish] #1234691
05/19/12 08:24 AM
05/19/12 08:24 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
This is good input. It wouldn't have occurred to me that the battery would afford plenty of run time to break the engine in.
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: jsully] #1234692
05/19/12 08:25 AM
05/19/12 08:25 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I agree, nice job
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: Finoke] #1234693
05/19/12 08:51 AM
05/19/12 08:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Nice stand but without any way of loading the engine for breakin its kind of a waste of time isnt it ?
I am truckless..
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: 340SHORTY] #1234694
05/19/12 10:16 AM
05/19/12 10:16 AM
okla.
sam64 Offline
sam64  Offline
okla.
makes it way easier to install inner valve springs after breaking in flat tappet cams.check for oil leaks,etc.
Re: Help wiring a Engine Run stand please! (Easy diagram) [Re: sam64] #1234695
05/19/12 11:29 AM
05/19/12 11:29 AM
Middletown , Ohio
Middletown , Ohio
It's a good way to check everything before the hassle of installing it in a tight engine bay . Finding leaks , low oil pressure , odd sounds or what ever . It can also be helpful breaking in the cam..
I was thinking about pulling the 440 out of my 37 dodge ratrod to do it. But I would like to build one of these instead.
I can get most of the steel from a buddy who's a welder. I can cut and weld it up myself.
I've seen guys use old k-members for this .
This is a awesome build ,and I'm looking forward to making one
Sorry , I'm not trying to hijack this thread ,It's just that this would be such a nice addition to the garage !
Im glad the wiring is straightened out, plus this is a bump for you
