wheel, tyre combo on 67 Coronet #1234519
05/16/12 04:51 PM
05/16/12 04:51 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
My Coronet looks a bit anaemic with the 14" rally wheels, so i think i'm going to fit some weld wheels i have on the car. They are 10x15 with a 5" backspace and i'm hoping to fit 265/70/15 tyres on the back, will they fit without cutting ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: wheel, tyre combo on 67 Coronet [Re: deaks] #1234520
05/16/12 07:28 PM
05/16/12 07:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Probably not on a 10 inch wide rim. 66-67 cars had small wheel wells and very low wheel lips. an 8" will be tight but will go. A 7" is ideal.
265 is a bit skinny for a 10" rim anyway. 275 is marginal. 295 fits decent, but agian, you wont' get that in a '67 wheel well.
Re: wheel, tyre combo on 67 Coronet [Re: TC@HP2] #1234521
05/16/12 11:07 PM
05/16/12 11:07 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
No 10" rim will fit a stock wheel well. A 275/60 on a 15x7 with 4 3/8" BS or 4.25" BS is about as big as you can go.
Re: wheel, tyre combo on 67 Coronet [Re: deaks] #1234522
05/16/12 11:17 PM
05/16/12 11:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I just put M/T ET Street Radials 255/60/15 tires with 15 x 8 (4.5 inch backspace) steel wheels on my daughter's 67 Coronet.
I would have to say that is as big a tire that I could safely put under there with everything being stock. 265/60/15 might barely fit but it would need to have a different backspace and probably custom wheel spacers. I was not willing to take that chance.
Right now I can barely get my index finger between the fender lip and the tire.
Re: wheel, tyre combo on 67 Coronet [Re: markz528] #1234523
05/16/12 11:41 PM
05/16/12 11:41 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I agree with the above, we put a pair of 255/60/15s on my brothers 67 20 years ago. As I recall we used stock 15x6.5" steelies and things were tight.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: wheel, tyre combo on 67 Coronet [Re: phantomx] #1234524
05/17/12 08:19 AM
05/17/12 08:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
on my old 67 I ran 15x6 up front with 215/75/15's and 15x7 w/ 275/60/15's. Tight fit but they will work. the 10's won't work...at least not w/o jacking it up a ton.
Coming soon!!!!
Re: wheel, tyre combo on 67 Coronet [Re: Mr.Yuck] #1234525
05/17/12 07:55 PM
05/17/12 07:55 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks, It's an R/T, so i dont want to cut it at all and i've already got one race car, just want to fill the wheel arches out a bit.
I might try and pick some steel wheels up and fit 255's
Mick
best 60ft 1.36
