Re: Bench Seat With aftermarket Floor shifter
[Re: kbcuda]
#1233899
05/15/12 06:04 PM
05/15/12 06:04 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Or anyone use newer seats and have them upholstered to match the original back seat. I just replaced the back seat covers...Let's hear/see some suggestions....
Anything is possible , swing by an upholstery shop and see what they can do.
See if the seats from a later model M body would work , or from a cordoba or magnum ...
I'm going to adapt the power seat track from a lebaron to fit a 69 A body and/or 69 B body.
[Re: JohnRR]
#1233900
05/15/12 07:36 PM
05/15/12 07:36 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
If your tranny is setup properly why shift it? Put it in "D" for drag and go for it. The tranny will perform better and be more consistant by itself.. Besides the column shifter gives it more of a sleeper look.
I am truckless..
[Re: cal_gecko]
#1233902
05/15/12 08:28 PM
05/15/12 08:28 PM
Posts: 1,945 roanoke va
kbcuda
roanoke va
Maybe he's got a manual valve body in it... ? Maybe he wants better control over when it shifts.. Maybe he wants to pretend it's a 4-speed, and do all the shifting whether it needs it or not...
All of the above!!lol..no manual valve body yet, but will be when i put the floor shifter..Eventually, (like 2 years) it will be a passon five speed with the pistol grip and a bench...bu t for now I want a floor shifter for the car ....
[Re: kbcuda]
#1233903
05/15/12 10:11 PM
05/15/12 10:11 PM
Posts: 1,443 Maryland
Dads426
Maryland
The B&M ratchet shifter works well with both std and reverse valve bodies. The short throw allows you to put it close to the bench seat and not reach too far foward. This is my old 64 Plymouth. If I had to do it again in this car the shifter would be elevated on a small box to make it a little easier to reach (that is how we have it in our current 64 Dodge)
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1233904
05/15/12 11:27 PM
05/15/12 11:27 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Ok. Do what I did in my 88 shorty. Slide the seat all the way forward then located the shifter. If your short armes get a mega shifter thats offered for pickups. It has a handle thats a bit taller. The mega shifter is a ratchet shifter that can be used in a forward or reverse pattern trans..
I am truckless..
