What does everyone use for motor oil? #1233777
05/15/12 02:10 PM
05/15/12 02:10 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
It's that time of year and I have to change oil in my Duster. I'm out of my stock of old Valvoline premium blue and EOS I used to run. I wanted to know whats the best for a mild 440 with a solid MP .528 cam? I know zinc is a high priority but i'd like to be able to get something off the shelf and not have to order from online. Are there any additives that are worth using? Thanks
Re: What does everyone use for motor oil? [Re: rck850] #1233778
05/15/12 02:17 PM
05/15/12 02:17 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Brad Penn 20w50 in the demon, Brad penn 20w50 bike oil in my harleys, Brad penn 10w30 in my Ramcharger, and mobil 5w20 in the charger.
My diesels get Delvac 15w40.
Re: What does everyone use for motor oil? [Re: Moparnut426] #1233779
05/15/12 03:15 PM
05/15/12 03:15 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I run Valvoline VR1 20-50.
67' charger 499 RB 10.57 at 127
Re: What does everyone use for motor oil? [Re: dragram440] #1233780
05/15/12 03:17 PM
05/15/12 03:17 PM
tboomer Offline
tboomer  Offline
Brad Penn 10-30....When it gets hot out,I mix 10-30 and 20-50 to get the pressure I want...
Re: What does everyone use for motor oil? [Re: tboomer] #1233781
05/15/12 03:30 PM
05/15/12 03:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Brad Penn racing oil
10W-30 in the drag race engine
20W-50 in the street driven 440
The oil gets hotter on the street than at the drag strip (trailer).
It is getting more and more available from distributors, but not in every town. After years of buying from an out of town race shop, a local NAPA store started carrying it and I bought it there this year.
Re: What does everyone use for motor oil? [Re: 440Jim] #1233782
05/15/12 03:48 PM
05/15/12 03:48 PM
Guitar Jones Offline
I have used 10w30 Mobil 1 in my flat tappet race car forever, no additives, no problems.
Re: What does everyone use for motor oil? [Re: tboomer] #1233783
05/15/12 04:05 PM
05/15/12 04:05 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Ditto!
Re: What does everyone use for motor oil? [Re: rck850] #1233784
05/15/12 04:14 PM
05/15/12 04:14 PM
an8sec70cuda Offline
Mobil One 15w50 synthetic or Valvoline VR1 20w50 depending on which car.
My Cummins gets Rotella 15w40.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What does everyone use for motor oil? [Re: an8sec70cuda] #1233785
05/15/12 04:21 PM
05/15/12 04:21 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Re: What does everyone use for motor oil? [Re: WheelsUp73] #1233786
05/15/12 05:04 PM
05/15/12 05:04 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
5 quarts of Valvoline VR-1 20W50, 4 quarts of Rotella 15W40 and 1/2 bottle of comp cams additive.
Brian Dunnigan
Re: What does everyone use for motor oil? [Re: '72CudaRacer] #1233787
05/15/12 05:15 PM
05/15/12 05:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I always use Valvoline VR1 racing oil. Ron
Re: What does everyone use for motor oil? [Re: 383man] #1233788
05/15/12 05:22 PM
05/15/12 05:22 PM
Renton Washington
Triple Threat Offline
Renton Washington
Brad Penn, Weight varies depending on engine clearances and time of year.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What does everyone use for motor oil? [Re: rck850] #1233789
05/15/12 05:40 PM
05/15/12 05:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The only thing I can recommend for oil is to make sure your engine has enough of it. When it doesn't, it didn't really matter what brand there wasn't enough of in it...
Re: What does everyone use for motor oil? [Re: rck850] #1233790
05/15/12 05:44 PM
05/15/12 05:44 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
delvac 15/40
Re: What does everyone use for motor oil? [Re: BradH] #1233791
05/15/12 06:14 PM
05/15/12 06:14 PM
Truer words have never been spoken...
Re: What does everyone use for motor oil? [Re: Guitar Jones] #1233792
05/15/12 06:32 PM
05/15/12 06:32 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Rotella 15W40
Re: What does everyone use for motor oil? [Re: WheelsUp73] #1233793
05/15/12 06:50 PM
05/15/12 06:50 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
This is an awesome oil. Lots of zinc, phosphorus, moly, and boron.
Plus it resists fuel dilution like a champ.
Re: What does everyone use for motor oil? [Re: rck850] #1233794
05/15/12 06:50 PM
05/15/12 06:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve tried a few over the years; Valvoline 10w30 all climate,Delo 15w40 diesel oil an even mixed my own using dino and syn. oils. Now I`m using Mobil-1 10w30 syn...............
Re: What does everyone use for motor oil? [Re: Thumperdart] #1233795
05/15/12 07:43 PM
05/15/12 07:43 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
Valvoline VR1 Racing Synthetic 10W30
Re: What does everyone use for motor oil? [Re: MOPARCHAS] #1233796
05/15/12 09:17 PM
05/15/12 09:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
20w50 VR1 with some Hughes additive for a little added insurance. Flat tappets and no problems.
Master, again and still
