Valve springs for 440 with 509 cam? #1231959
05/11/12 11:33 PM
05/11/12 11:33 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
I'm looking for valve springs to put on a 440 with a 509 cam. I've been told to find a good single spring, such as the mopar P5249848, what other brands are comparable?
Re: Valve springs for 440 with 509 cam? [Re: Montclaire] #1231960
05/12/12 10:09 AM
05/12/12 10:09 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A set of these should be fine.
http://www.summitracing.com/parts/CCA-911-16/
http://chucker54.stores.yahoo.net/comcambrbhig.html
I love the 509 cam on a 440 install it at 102 to 104 intake centerline.
Re: Valve springs for 440 with 509 cam? [Re: Montclaire] #1231961
05/12/12 03:05 PM
05/12/12 03:05 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Put a "wanted" ad out in the Big Block Parts Classifieds on this site if you don't see some for sale already.
I did a few years ago and got more replies than I needed. Lots of guys are selling their "take-off" springs that came on this Edelbrock heads. They work well with a MP 509 cam.
Re: Valve springs for 440 with 509 cam? [Re: Dean_Kuzluzski] #1231962
05/12/12 05:24 PM
05/12/12 05:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a brand-new set of springs, retainers & locks off my Stealths; send me a PM if you're interested.
Re: Valve springs for 440 with 509 cam? [Re: Montclaire] #1231963
05/12/12 06:19 PM
05/12/12 06:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
your cam sheet would have come with a recommended spring strength.
Re: Valve springs for 440 with 509 cam? [Re: topside] #1231964
05/13/12 01:09 AM
05/13/12 01:09 AM
Scranton, PA
Scranton, PA
PM sent
Re: Valve springs for 440 with 509 cam? [Re: Montclaire] #1231965
05/13/12 08:04 PM
05/13/12 08:04 PM
Lebanon, TN
bronzegtx Offline
bronzegtx  Offline
Lebanon, TN
I have a good set of springs that i took off a set of Eldelbrock heads if you are interested. My email is siscosautorepair@yahoo.com. I can send pics if needed.
Re: Valve springs for 440 with 509 cam? [Re: bronzegtx] #1231966
05/13/12 08:56 PM
05/13/12 08:56 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Shouldnt this post read
"What is a better cam than a 509 for my 440"?
I am truckless..
Re: Valve springs for 440 with 509 cam? [Re: 340SHORTY] #1231967
05/13/12 11:29 PM
05/13/12 11:29 PM
Scranton, PA
Scranton, PA
No, not really.
Re: Valve springs for 440 with 509 cam? [Re: Montclaire] #1231968
05/13/12 11:44 PM
05/13/12 11:44 PM
Scranton, PA
Scranton, PA
Just wanted to ask about the Stealth springs, from what I am seeing they are singles with a damper, rated for max .600 lift, which is fine. It looks like the locks are only rated to .510, any issues here?
Also it says that the stealth heads are clearanced for larger diameter springs, will the stealth springs fit a stock 915 head? Their site lists the od on the spring as 1.550"
Re: Valve springs for 440 with 509 cam? [Re: 340SHORTY] #1231969
05/14/12 10:09 AM
05/14/12 10:09 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
509 cams rock just many do not have the knowledge to install them right and tune the advance rate and carb to make them rock!
They sell Summit cams for those guys! :-)
