what an experience UPDATE pict.
#1231812
05/11/12 08:58 PM
05/11/12 08:58 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
racing the dart last night at are newly reopening of irwindale dragstrip. i had the hood off since it was in for painting. in the final round of the money bracket i was just about to cross the line and HOLY YOU KNOW WHAT i cant see any more. i thought it had split a radiator hose, but what had happened is i pushed out the oring on the filter. there was so much smoke and oil that i could not see where i was on the track. the shut off at that track gets narrow and dark. after pulling over and the saftey crew arived it caught fire from the oil on the headers. it was put out quick and there was no damage. i should have listened to you guys about the choice of filters. it was the napa 1515. a lesson learned in life. its funny that that same filter had about 20 runs prior. i got lots of cleanig to do this weekend as oil is all the way down the leftside of the car, roof door and major mess in the engine compartment.
Re: what an experience
[Re: Deepockets]
#1231814
05/11/12 09:09 PM
05/11/12 09:09 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How much oil pressure did the engine have and was it a standard or high volume pump. I just replaced my high volume pump with a standard volume pump and my oil pressure seems much better now but I will find out for sure tomorrow at the track.
[Re: Deepockets]
#1231815
05/11/12 09:11 PM
05/11/12 09:11 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
Glad you are OK. What was final round result?
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: 73swinger]
#1231816
05/11/12 09:52 PM
05/11/12 09:52 PM
Deepockets
glendora, ca.
it's the high volume pump. i do think the standard would work. as the the final round, we agreed to split the winnings with a $20.00 side bet. we were .003 different on r/t's and i did'nt run my number because of the issue.
[Re: Deepockets]
#1231818
05/11/12 10:10 PM
05/11/12 10:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Glad you kept it off the wall, good driving We saw you disappear in a smoke cloud and thought bad things had happened.
"Just a Bracket car dressed up like a streetcar"
[Re: Thumperdart]
#1231822
05/12/12 04:19 PM
05/12/12 04:19 PM
Posts: 781 wine country
8urvette
wine country
Sorry to hear this but it could of definately been worse for sure............good save. How can the rubber gasket let go............I caveman tighten mine to the point where it`s almost metal to metal and never have issues...........
I built an import motor for a friend and he did the same thing.... We fired the engine up and oil squirted out of the back side of the engine, and on this engine its faster to remove the head then the intake to see what happening, or go from the bottom and remove both axles, and upper control arms etc. etc. etc. so we poped the head off, and couldn't find the leak... cleaned the head gasket (single layer multi use type) put it back together (hours of checking everything else). fired it up and same thing. With a few small mirrors and a third person we could see it spraying from the oil filter o ring- he crushed and split the o ring when he put it on.... so be careful with that
[Re: topbrent]
#1231825
05/12/12 07:56 PM
05/12/12 07:56 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
isnt that the same as the WIX filter?
glad your OK. it could have been much worse
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1231826
05/12/12 08:06 PM
05/12/12 08:06 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Yep that is a WIX filter I ran the plain ol WIXs for a long time with 80+ psi and have never lost 1.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
