what an experience UPDATE pict. #1231812
05/11/12 08:58 PM
05/11/12 08:58 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
racing the dart last night at are newly reopening of irwindale dragstrip. i had the hood off since it was in for painting. in the final round of the money bracket i was just about to cross the line and HOLY YOU KNOW WHAT i cant see any more. i thought it had split a radiator hose, but what had happened is i pushed out the oring on the filter. there was so much smoke and oil that i could not see where i was on the track. the shut off at that track gets narrow and dark. after pulling over and the saftey crew arived it caught fire from the oil on the headers. it was put out quick and there was no damage. i should have listened to you guys about the choice of filters. it was the napa 1515. a lesson learned in life. its funny that that same filter had about 20 runs prior. i got lots of cleanig to do this weekend as oil is all the way down the leftside of the car, roof door and major mess in the engine compartment.
Re: what an experience [Re: Deepockets] #1231813
05/11/12 09:06 PM
05/11/12 09:06 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
it's rustproofed for the year.
Re: what an experience [Re: Deepockets] #1231814
05/11/12 09:09 PM
05/11/12 09:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
How much oil pressure did the engine have and was it a standard or high volume pump. I just replaced my high volume pump with a standard volume pump and my oil pressure seems much better now but I will find out for sure tomorrow at the track.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: what an experience [Re: Deepockets] #1231815
05/11/12 09:11 PM
05/11/12 09:11 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Glad you are OK.
What was final round result?
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: what an experience [Re: 73swinger] #1231816
05/11/12 09:52 PM
05/11/12 09:52 PM
glendora, ca.
glendora, ca.
it's the high volume pump. i do think the standard would work. as the the final round, we agreed to split the winnings with a $20.00 side bet. we were .003 different on r/t's and i did'nt run my number because of the issue.
Re: what an experience [Re: Deepockets] #1231817
05/11/12 10:00 PM
05/11/12 10:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Way to keep it between the rails....that had to be pretty hairy.
Re: what an experience [Re: Deepockets] #1231818
05/11/12 10:10 PM
05/11/12 10:10 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Glad you kept it off the wall, good driving
We saw you disappear in a smoke cloud and thought bad things had happened.
"Just a Bracket car dressed up like a streetcar"
Re: what an experience [Re: Just-a-dart] #1231819
05/12/12 02:22 PM
05/12/12 02:22 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I'm glad you and the car are ok!! Thanks for sharing the heads up about
Napa filters!
74 dart sport 440 www.Csucarbs.com
Re: what an experience [Re: Deepockets] #1231820
05/12/12 02:32 PM
05/12/12 02:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sorry to hear this but it could of definately been worse for sure............good save. How can the rubber gasket let go............I caveman tighten mine to the point where it`s almost metal to metal and never have issues...........
Re: what an experience [Re: Thumperdart] #1231821
05/12/12 02:45 PM
05/12/12 02:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Scary stuff!
Glad you and the car came through it ok.
Re: what an experience [Re: Thumperdart] #1231822
05/12/12 04:19 PM
05/12/12 04:19 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I built an import motor for a friend and he did the same thing.... We fired the engine up and oil squirted out of the back side of the engine, and on this engine its faster to remove the head then the intake to see what happening, or go from the bottom and remove both axles, and upper control arms etc. etc. etc.
so we poped the head off, and couldn't find the leak... cleaned the head gasket (single layer multi use type) put it back together (hours of checking everything else). fired it up and same thing. With a few small mirrors and a third person we could see it spraying from the oil filter o ring- he crushed and split the o ring when he put it on.... so be careful with that
Re: what an experience [Re: 8urvette] #1231823
05/12/12 07:45 PM
05/12/12 07:45 PM
Utah
topbrent Offline
topbrent  Offline
Utah
So what is the recommended oil filter to use now?
Re: what an experience [Re: topbrent] #1231824
05/12/12 07:55 PM
05/12/12 07:55 PM
glendora, ca.
glendora, ca.
well i did'nt have the 5151R, it was just the 1515. it did grow longer. i'm now going to bite the bullet and get the system one and be done with it. the question is if any one out hear has had the similar thing happen and how did your bearings look? i don't want to take apart if ness but will. lets hear if you have any imput. i did drain the oil and theres a lot. it did'nt run dry or even close.
Re: what an experience [Re: topbrent] #1231825
05/12/12 07:56 PM
05/12/12 07:56 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
isnt that the same as the WIX filter?
glad your OK. it could have been much worse
Re: what an experience [Re: sixpackgut] #1231826
05/12/12 08:06 PM
05/12/12 08:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Yep that is a WIX filter I ran the plain ol WIXs for a long time with 80+ psi and have never lost 1.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: what an experience [Re: dusturbd340W5] #1231827
05/13/12 12:07 AM
05/13/12 12:07 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
That sucks bud, glad nothing drastic happened like the gaurdrail or total burn down. Good luck in the future
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: what an experience [Re: Thumperdart] #1231828
05/13/12 01:32 AM
05/13/12 01:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pics or didn't happen
Re: what an experience UPDATE filter pict. [Re: Al_Alguire] #1231829
05/13/12 11:50 AM
05/13/12 11:50 AM
glendora, ca.
glendora, ca.
hey al, yea it did. i've spent hours sruirting palmolive on the car and engine. it came out clean except the felt on the driver window has oil in it that i'm scratching my head in how to clean it since every time the window goes up it transfers oil to the glass.
Re: what an experience [Re: pittsburghracer] #1231830
05/13/12 11:57 AM
05/13/12 11:57 AM
PA.
"Little"John
"Little"John
PA.
I just changed out a high volume oil pump on my duster as the pressure went up over 130# during a pass. I went with a standard pump this time as several other members have had issues also. Thank God I had a racepak in the car so I could see what was going on during my pass.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: what an experience UPDATE filter pict. [Re: Deepockets] #1231831
05/13/12 12:02 PM
05/13/12 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure wasnt by-passing enough oil at the pump check
valve
