Transmission fluid ? #1231036
05/10/12 01:46 PM
05/10/12 01:46 PM
MI
marklock Offline OP
I tried too hard for a custom title
marklock  Offline OP
MI
Going to change the transmission fluid in my 2000 Dakota with automatic this weekend and was wondering how many quarts of fluid to buy ? Any brands to avoid or one that is best to use ? This is for a daily driver that just turned a 100k and shifts fine, no towing or heavy use. Will be changing the filter also if it helps.
Re: Transmission fluid ? [Re: marklock] #1231037
05/11/12 01:09 AM
05/11/12 01:09 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
8 quarts is usually in the ballpark range.
ATF+4 is a completely synthetic fluid so just make sure its got the licensing # on the bottle and you'll be fine. I have poured everything from Mopar to walmart branded atf+4 into our fleet and besides the price difference the bottle sure looked identical...
If you've got the 4.7 then make sure to get both filters for the RFE transmission. Most stores sell them as a packaged set but others sell them individually.
Re: Transmission fluid ? [Re: 135sohc] #1231038
05/11/12 02:02 AM
05/11/12 02:02 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got a 42rh, 46rh, and a 46re using walmart atf+4.
getting ready to service the 99 dodge with the 46re next weekend as it just came back from a 4000 mile trip towing a trailer with a car on it plus a truck bed full of household stuff..
Tony
70 AARCuda Vitamin C
Re: Transmission fluid ? [Re: 135sohc] #1231039
05/11/12 06:15 PM
05/11/12 06:15 PM
MI
marklock Offline OP
marklock  Offline OP
MI
Thanks guys, appreciate the information. The motor is a 3.9 so the trans should have 1 filter.
